Installing your own electronics
Ductboy
I was wondering how feasable it would be for me to install a Raymarine 120 with radar, myself. I am skilled mechanically, but not really electrically.
These units seem to be plug and play with the exception of the power wiring. There is an exisitng chartplotter on the boat I am buying, but no radar. I would need to buy a new chart disc for the existing 8 year old Northstar 962 unit, so I figured now is a good time to upgrade the old and get an all in one. This would mean that I could reconfigure the hole in the helm, instead of making another large hole for a stand alone radar.
I already own a Navionics Gold chart that will work in a C120.
The boat was advertised as "radar ready" which hopefully means that there is a pull wire to get the wires up to the hard top. There is a bump up on the HT to accept a radar.
I have noticed on sisterships that the radar is mounted directly to the hardtop bump up area with no shims, so hopefully getting the correct angle should not be a problem.
It seems like a no brainer, install head unit, replace antenea and wiring with new, plug in. Mount radome , snake wiring, plug in. Attach old power wiring to new unit (hopefully)
What am I missing.
Dan
I installed own Raymarine system. I have: E-120, E-80, Radar, Sonar, Ships heading sensor and the gps sensor. As long as you follow all the templates the pieces snap together. The radar dome gets power from the C-120 so there's only one wire to fish. Do be sure to align the dome fore/aft correctly or all your bearings will be off (though you can adjust it on the C-120 if you make a small mistake). Unless the old unit was a Raymarine you can probably forget about using the old power cord, these are proprietary.
Phily, thanks for the input.
By power cord I was actually refering to the power wiring from the boats 12 volt breaker panel.
I did my own radar, bottom machine, gps and autopilot all tied into a Raymarine C 80 series.
The install was fairly simple, however the radome failed while still under warranty and I have had continuing issues, off and on with the autopilot.
As Phillyteach said, the install is fairly simple.
Instead of a fixed mount, I got the "PATRICK" electric/hydraulic self leveling radar mount. This allows me to set the angle of the radome for different running angles - sayif I was planing or at displacement speeds running in a fog, rain etc.
It's a nice feature and worth a look.
Tell me more! I changed the mount angle several times when I installed my Furuno. I thought some type of electrically adjustable mount would be ideal.
Wow. Thousand dollar radar mount. I'm duly impressed (seriously, no sarcasm!).
$1,000 ?
I paid something over $600.
Think about it. Either you set the radome up to be accurate at planing speed or displacement speed.
If I want to run a slow cruise in the dark, say 13-16 kts I have more bow rise than running at 21 kts and I want that radar to be accurate. If it's foggy or I get caught in a florida thunderstorm (they do come up quick & thick here) and I need to run displacement speed, the same holds true. I don't want to be pointing at the sky or at the water.
The system works great. 2 years ago on a trip back from the keys we were able to circumnavigate and out run a thunderstorm that ended up with a visable funnl cloud. Got some great pictures.
I consider the radar a safety item.
For me the self leveling mount was well worth the additional $200-300 investment.
Not a lot when you consider the cost of ALL the electronics.
On the install, make sure you have a large enough breaker for the new radar. On my last boat my older one was not enough to power the new unit. Many more bells & whistles needed extra power with the larger display.
