I read this advice recently from a boating publication:
"A pressurized water supply should never be used to feed the raw-water pump of an engine equipped with a water-cooled exhaust system. Applying even a low-pressure supply of water to the raw water pump creates the risk that the water will flow through the pump when it's not operating, or deliver an excessive flow of water if the engine is operating slowly. Either condition can fill the exhaust system with water, which can back up into the exhaust manifold and enter a cylinder." He then advised drawing water from a container instead.
Is he saying I shouldn't use a garden hose and muffs on my fresh water cooled Merc 8.1? Being that it's a trailer boat with over 800 hours and I've successfully used muffs maybe a hundred times, am I missing something here?
Peter
Peter
