Intermittent warning buzzer
JellyFish
My warning buzzer failed to go off when the ignition key was turned. I should hear two clear loud beeps but instead I have been hearing no beeps and/or “gargle" beeps, sometimes very weak. If I start & warm up the engine, turn off the ignition and turn back on, then I get the 2 loud & clear beeps as I should.
My understanding is that the warning buzzer monitors 3 sensors: drive lube oil level, water temp & oil. Is this correct? Also, the water and oil have two sensors each, one is the actual sending unit to the gauges in the helm and the second is the sensor to the warning system??
Has anyone experience this before?? I welcome feedback and suggestions before I start replacing these parts/sensors.
2001 SeaRay 240DA, 5.0L EFI, raw water cooled.
Alex
Check the voltage to the beepers at both times before you do anything. Are they the constant monotone squeal kind?
