Is this battery the most commonly used in your larger cruisers. My silverton has 2 of these batteries that supply starting for the port and starboard engines and house needs (equally divided) also. It seems to me when cleaning the boat earlier last weekend, the batts started fully charged on my portable (land) genset, the genset ran out of gas, and I continued cleaning listening to music on the bridge, with just about all interior and exterior lights under my hardtop on. The port battery ran down in about 1.5 hours. Is this normal? I know it is difficult to answer without adding all the amp hours etc and doing it scientifically but I guess my questions are:
1) I have a "smart charger" 2/10/15 amp by black and decker and i took the battery out of the boat and charged it until it says "ful" on the display, so it is fully charged. This charger will also give some type of fault code if there is something like a sulfated batt. etc or something internal wrong with it. It did not give any codes. BTW the battery was placed into service 4/05, so it is going on 3rd season. Batts always stored on the boat, terminals disconnected, full at the start of fall. Question: Should I use the "recondition" feature of the smart charger to "recondition" the battery?
2) How do I know when it is time to replace this battery?
3) Where can I buy this type of interstate battery and is this what most of you folks use- it is a deep cycle battery meant to sustain repeated deep discharges/charges and also deliveres sufficient cranking amps to start the engines.
thanks
thanks
