- Oct 20, 2002
- 10503
- 3,677
How about a transmission that uses water instead of oil?
I was thinking of a small 5hp B&S driving a shaft that circulated water inside an enclosed resivour.
To make the turning shaft pump water past the Rotor blades, use a Diverter plate.
One set of holes facing the pump would let the water circulate back into the resivour unimpeded. That would be neutral.
Turn the plate another Click and the water from the pump blades is diverted to the Rotor blades to do some work.
Divert the water in a different direction for Reverse.
I'm not the sharpest pencil in the box. If I think of something, there's usually something like this out in the field, let me know about it.
