Inverter Size
fountain27
The admiral "needs" to watch TV rb2@gr5t night to fall asleep. We are planning to spend a week on board and the generator might not get fixed before we leave.
I have a lightly used deep cycle battery in my garage and was thinking of buying an inexpensive inverter. Question: what size inverter would I need to power a 13" tv? I would prefer to keep the "luxury" items complete independent of main battery bank.
300 watts should be more than enough to run a small TV. Actually, 100 watts is probably big enough, but having a little extra umph never hurts.
300 to 400 watts should give you some margin for error. You can look at the back of the TV and find the amps used by the device. Multiply that by 120 add 10% and you have your exact needs.
So if the TV draws 2 amps x 120 volts = 240 watts +10% = 264 watts
I use a 500w for a 22"LCD and the kids PS2 with no problem
inverters are a item that changes dc to ac, it's not a good mix. Your better getting a tv thats dc, most new tv , lcd, flats are ac that convert to ac outlets for you home. Get a cheap tv that haves the tranformer in the cord, make sure it's a 12 volt, cut it off hook to boat battery, best usages for the volt.
