ISO Class I
vic33004
is there any reason why a set of props that are sent out for reconditioning would be conditioned to an ISO class II instead of a class I assuming that the wheels are capable of it?
I recently had my 17"D props fine-tuned from good class 2 to class 1 by a PropScan shop and they are noticeably smoother underway. Class 2- cheaper for you and easier/quicker for the mallet pounder, but I believe most good shops these days use Class I as their standard target unless the customer has stated lesser ( or greater) needs. However, slower boats w/slower turning props (especially displacement-speed boats) may not benefit as much from the higher classes tuning to make it cost effective, I'm guessing.
I understand how prop scan works, but the repair is still done with a mallot, hammer, and dolly. How accurate is that?
Just got done looking at a set of nibral props done by prop scan about 21 inches in diameter. Props looked perfect, except for leading edges were deformed. It was hard to see, but easy to feel. Props came with a chart that showed that they scanned perfectly after repairs were made. If they use a computer to get to within .001, than how can the repair be that close? I thought that they had a mold, or jig to accurately set the prop to the original specs, but they don't.
