jack stand bottom paint
ctcruiser
well I think I will be ok but since this is the first time I bottom painted the boat I fifgured I would ask. First the bottom paint job came out great and I am really proud of it. The only mistake I made was that I forgot to tell the yard to put paint on by where the jackstands are when they get ready to luanch the boat for her 6 month bath and I could not paint it because the stands where in the way. The bottom was painted before with micron csc so that is what the old paint is under the stands. Should I be ok in those 4 spots whear the stands where?
I use an extra stand and move them one at a time. If you have last years CSC under there, it will be fine. CSC is multi-season paint.
It sounds like the boat is in the water. I wouldn't worry about it until you pull it again. Just ask the boat yard to touch it up when they pull it again or if possible, put the jack stands in a different spot so you can do it.
Use an extra stand next time , and put a piece of wax paper between the pad and the boat when you move the stand.
