Jet boats
Roy
Could someone summarize the pros and cons of small jet boats vs sterndrives? I'm thinking of one like the Yamaha 230 SX. I know some of the obvious differences, but I'm sure there are some "got chas" regarding jets that only someone who has owned one might be familiar with. Thanks.
When my kids were little (grade/middle school), I owned a jet boat because I worried about them hurting themselves on the prop. The boat was less maneuverable at low speed and the lack of efficiency of the impeller versus the prop were two criticisms. However, everyone enjoyed the ability to do 360's and make sharp cuts like a pwc. When my kids hit their teens we moved to an inboard.
I know that more recent jets have much more power. I don't know if the economy has improved. Something else to think about is that impellers suck up muck and sand in shallow water. Just because you don't hit bottom doesn't mean you're not damaging your boat by generating wear on the impeller. In sea weed areas ours would bog down as it wrapped the sea weed around the impeller, also.
The reason I like the boats better than pwc is that you can share the fun with more people, but if you follow that reasoning too far you'll end up in a pontoon boat!
Make sure there is a shop that can repair the jet boat nearby. It is much easier to find mechanics for stern drives.
Also, jet boats should not be left in the water, so you either need to put it in and out each time, or get a jet dock.
More cons than pros from the marine mechanics at my marina. They seem way over priced to me.
There is virtually zero maintenance for a jet boat stored on land. ( plugs are the only item )
Seaweed will block ur intake grate. But seaweed could foul a prop. There alot fun.
Size for size id take the Jet boat.
take a look at the GPH the engines on the same boat use. i've had a jet RIB and its true they foul with seaweed just like a prop, but with the outboard i have now on my RIB i can either back down to clear it or tilt the motor up. in the jet RIB i had to jump in the water and manually clear it. there have been a few places with lots of seaweed that this was a major PITA. i also found the Avon dealer would not service the jet motor or drive, the last yamaha dealer that had the boat refused to work on it again because of the difficult access. on a larger boat the access may not be an issue. a four stroke outboard should get remarkably better fuel economy over a two stroke jet.
Safety? Ever seen a person who was hit full in the face or groin with the jet blast? Not a pretty sight. I know two people who had the Yahama 230 and felt that they were very rough riding in a chop. Certainly the slow speed maneuvering is an issue. Less effecient than outboards. Another issue is how to flush the engines/drives after salt water use?
Ever see a person hit by a prop ?? Lets be reasonable ! All have pros and cons... Jet boats are a " BLAST " How them bravo 3's hanging ?? Ill take a pump any day over that train wreck.
In the process of selling mine due to lack of use. I found that having several boats including a 21' ski boat and 2 PWC's, the jet boat just sat. It didn't have as much of the fun factor as the PWC's, didn't tow anywhere's near as well as my 21' and had a rough ride. Not familiar with the one you are looking at, but on the Mercury sportjet, changing the jet oil was a real pain, so I gave up doing it myself and had the dealer do it every fall.
Every boat is a compromise of some sort. It just depends on what you are going to use it for.
Lon
"Another issue is how to flush the engines/drives after salt water use?" They Yamaha's have a garden hose hookup in the boat for each engine to flush it out.
