Jet Drive Operation
boathandler
On April 17, Virgil Chambers and I operated a Yamaha AR 210, a 21-foot shallow-to-moderate v-hull boat which has twin jet drives, to learn how it is similar to, and different from, prop-driven boats with directed thrust. Thoughts on basic control of this vessel:
GENERAL:
At any throttle setting, even at dead idle, forward gear provides much more directional control than does reverse.
DRIFTING DEAD IN THE WATER:
If lying bow upwind, the boat will remain that way, and make slow sideways leeway. If lying stern upwind, it will remain that way, and make headway.
STERN-TO-WIND:
In wind, reverse is effective in holding the boat in place with the stern upwind. Ferrying side-to-side stern-to-wind can be done.
STEERING STRAIGHT:
Pretty much the same as usual. Practice it using the no-wake rpm setting (2200) initially, then turn it off in calm conditions and practice at dead idle (1750).
STOP THE BOAT UNDER CONTROL:
The basic standard stop works pretty well. I would add light throttle on the outside engine, if needed to help keep the bow straight. There is no urgency stop. If you shift into reverse too late, you hit. Using the no-wake feature in reverse may help some.
SPLIT-ENGINE TURN-AROUNDS:
Splitting the engines causes this boat to turn in the wrong direction, and to make headway. Adding throttle on the reverse engine increases the headway.
BACK-AND-FILL TURN-AROUNDS:
The back-and-fill method was successful, but only by using both engines together. The outside engine alone, in reverse, with or without throttle, was ineffective.
OTHER INPUT:
I have learned from a colleague that some twin jet drive boats do turn in the “right" direction when splitting the engines, so I would not generalize across-the-board what I observed on this Yamaha.
CONCLUSIONS:
Do: Forget the “wheel right, port engine, wheel left, starboard engine" saying; use both engines together, in the same gear.
Do not: Split the engines; add significant throttle in reverse.
What kind of jets where they, and what kind of a control setup? Two stick or four stick? Never run a twin jet that does some of that stuff....
Me, neither. It has the combined throttle/shift levers. The jets are standard, as far as I can tell…steerable nozzle with the dropping clam shell for reverse…such as it is.
I talked with a Yamaha dealer today at the Bay Bridge Boat Show about the Lake Anna experience (split engines turning the wrong way, and all the rest). He said that none of his 210s or 230s do that. He is a licensed captain, and he personally tests all the boats and trains all the customers who buy one, and none of his boats ever did that stuff. His best guess to explain this anomaly is that the linkages from throttle/shift levers were reversed; it was a mechanical problem.
I asked him if that mechanical problem would be a factory problem or a dealer problem, and he said it was a factory screw-up.
The other odd thing is that the dealer guy never said boo. I said aloud that the boat was turning the wrong way on split engines, and the dealer guy saw it, but he was silent.
So, kindly disregard this thread. It's meaningless.
I'd like to know how they handle in the typical 1' chop on the Bay. The wife wants a jet boat for our Still Pond house where we'll spenf most of the time kicking around in Still Pond but we also want something we know we can run up the Granary on the Sassafras in the evenings when weather permits. Several ROs here have told me that a jet is not the way to go. I'm still pushing for a small W/A with twin outboards and a waverunner for screwing around in the creek.
Nothing first-hand here, but my gut sense is that it would give a bumpy, wet ride. I may know more in about a month, after a trip to Sacramento, CA to teach some state gov folks how to handle this boat, which was the reason for the Lake Anna trip. But, my teaching specialty is strictly close quarters, around piers and slips, with wind or current. So, I may not get to do any point-to-point, open-water stuff. Then again, a guy is coming up from Texas who has driven this model boat, so I'll try to pick his brain.
