Johnson 110 outboard problems
WillRivera
I just bought a 1988 Sratos with a Johnson 110hp outboard motor on it. When you try to start the boat, it will just continue to crank but never start. I have found that if you open the lid on the motor and flip this emergency start red switch, it will start but idles rough. The moment you try to put it in gear it stalls. If you do happen to get it in gear, the motor will run fine at top speed (wide open) but if you back her down to a crawl-she'll die.I changed out the fuel filter and the plugs but still the same deal. I don't have a clue, please help. Thanks
Is this a new problem or was it doing this during the initial sea trial when you were buying it?
