Just A Reminder When Winterizing
carver 2557
Don't forget when winterizing your boats this fall to add "Fuel Stabilizer" to the fuel tank...Many people forget to do this and it can lead to problems in the spring...
It's cheap insurance towards a trouble free spring start up..
Make sure it is for ethanol, or you'll have really BIG problems in the spring
And add it early so it gets a chance to run thru the system. Don't just dump it into the gas tank and forget about it.
I just did the anti-freeze thing with by engine...I mixed 50/50 in separate containers as per instructions...When I checked, it 2 of the mixed bottles were only god for -10f , while the other 2 were good for -50f...I think i got a bad gallon...
Always check the strength before using it...I figured that my cheapo tester just saved me a cracked block...
The suggestion to not use full strength is for cooling issues. 50/50 cools well and full strength does not. With freezing though, full strength gives about twice the protection of 1/2 strength, so I always use full when I run it thru the engines. When I backfill the block, I use 50/50 because minus 34 protection is fine here.
It depends on what you are talking about...if you mean the -50/60/100 PG stuff for winterizing.... that is supposed to be used full strength...if you are talking about the PG stuff that comes undiluted with water (like Sierra coolant) and can be used as an engine coolant then you should mix it with water for max effectiveness...undiluted Sierra will actually slush up at a higher temp than if you dilute it properly with water...I have found that the PG coolants that are to be diluted need to be used at a 60%AF 40% water mix to get it down to -35 freeze protection...I have a special hydrometer that's for PG mixtures and used to mix up the Sierra or other marine PG coolants but now I just use the -100 pre-mix and when checking it with the hydrometer it gives you freeze protection all the way down to -54 (as low as the hydrometer can measure)...the -50/60 stuff slushes up at too high a temp for me even though it 'should' be OK...
I apologize to all the important people on this board for my next:
In all the years I've owned boats that sat over the winter I never ever used any kind of additive to the fuel. I never ever had any problems with bad gas.
My most famous tale is the 32 Plymouth given to me in High School. It sat for 15 years in a Garage.
I had it running in an hour. That old gas worked just fine.
The one time I bought a Boat/Motor/Trailer from a guy who'd put Stabil in the gas, I had trouble with the Carb every time I let it set for a few days. The Stabil caused that Rubber tip on the Needle valve to swell and it sticks up in the seat if it sets very long with fuel in the Carb.
(an aside there. At one time George asked me to send him that carb. I didn't know who he was at the time though)
Rather than Stabil, I'd bet you would be better off to run the engines out of fuel. Leave nothing in the carb or fuel pump over the winter. That's for Gas/Carb models.
I'll not say Stabil is bad stuff. Just that I don't think it does anything at all.
If you have two tanks, make a test. Put Stabil in one. See what happens next spring.
In Alaska I drained my engines and the sea water stuff as well. I blew that all out with air too.
I had some trouble the first season. One Riser was cracked in the spring. I had it welded and the next fall I was a lot more diligent in blowing the water out.
If you have older out drives, there are some plugs to pull and on some Water Manifolds there are some plugs to pull.
I always took the Batteries inside for the winter.
One tidbit for the guys who leave heat in the boat. A fan is much more of a life saver than a light bulb.
The moving air is better than still heated air. Incandescent bulbs will die in the cold, the curly light bulbs don't produce any heat at all. A fan is a better deal.
Whatever you do, don't turn it off. leave it run all winter long.
Wayne, thanks for the reminder! I'll be at the boat this weekend and will add the Sta-Bil and top off the tank on Sunday. I have done this every year for the 18 yrs I've owned this boat and have NEVER had a fuel or carb problem. [Sorry Thuddie].
What's all this talk about fuel stabilizers? Winterizing around here means putting the eisenglas back on, loading the portable propane heaters and throwing a couple of long sleeve shirts in the boat. Can't imagine the expense of boating with a limited season .. we enjoy the boat year round!
LOL Dave. I do it 'cause the same tank of gas usually lasts me well into the spring. If I do use several gallons of gas, I top the tank off on my way back to the slip. But I'm with you on year round boating!!!
