How do you know if you need a short shaft kicker or a long shaft kicker? I have approx. 20 inches from the top of my kicker bracket to the bottom of the boat.
Scatman38
a long shaft should work but if you can get an extra long.. 22 to 25" it might be better to make sure the prop does catch air when the boat pitches in waves/wakes
Long shaft generally has 22" from mounting bracket to anti-ventilation plate. If your kicker doesn't have enuff power to get you on plane(few do) you only need the ventilation plate to be submerged at your highest speed.
