Kill lanyard
In the know
Do you always use your safety lanyard when operating your boat or dink?
My boat does not have safety lanyards, however my CC does, if I'm alone, I wear it. My dink has one and I always attach it.
Only when I'm alone or with just the kids (meaning, no one else on the boat that can drive it).
Do you have an extra kill lanyard in case you go overboard? Without an extra it is difficult for someone on the boat to start and navigate back to you.
On my boat, the kill lanyard simply flips a switch when pulled, so if I exit the boat with the lanyard on, someone can always just flip the switch back up and get the boat running again.
Not always in the dink, but that is changing. We had a run-a-way dink on the creek this weekend and it could have been prevented if the operator was attached to the kill switch properly. She's really lucky that when she got popped out because she wound up outside the tightly circling dink. This was the second time I've seen this happen. In the first case, the guy was inside the circle and had to jump up and grab the throttle! No one was able to get the boat since we were all ashore and there was no one else around with another boat. Geeze he was lucky!
No kill switch on a 47' Chris Craft and I do not leave the helm without the engines in neutral.
My CC (sold) had one and I used it religiously. My houseboat (top speed 7 knots) does not and as I'm always indoors and can't fall out, I've seen no reason to install one. Thinking about that, now.
The dink is powered by an electric trolling motor... if I fall out I'll just grab it as it goes by on the next pass.
Anytime the boat is on plane. And I did get pitched once. Biscayne Bay. Swam over to the boat and climbed back aboard.
Kill switch and PFD anytime on plane. NO EXCEPTIONS, especially if I'm alone.
Willy the one that dumped the lady this weekend was an Avon 340 with a 15hp outboard. The boat that dumped my buddy (many years ago) was an aluminum 15 or 16 footer with a 25 hp outboard. We used it for skiing on the Delaware north of Dingman's Falls. He pulled the starting cord while it was in gear and it dumped him right over the transom. I think the lady just made a sharp turn and it popped her out of the dink.
In my younger years I had a skiff with a 12hp Wizard (Merc) that was ALWAYS in gear (no neutral or reverse). Starting that thing was always a "thrill"...
I saw a guy get flipped out of his aluminum 16 fter. He wasn't going real fast and not on plane, but he didn't slow down for an approaching wake. He didn't have a kill switch, float cushion or PFD. He finally managed to climb back aboard after 1/2 hr when the prop got tangled in the tules and the engine stopped. He wasn't hurt, but he sure was tired!!!!
My 25 Mariner has one, and I clip it on everytime I throttle up.
It is the most hatefull thing to get where I'm goin, and reach for something to use, and pull that lanyard out of the Toggle which kills the engine.
Then I have to thread it back in...etc. But I use it every time I go above a trolling speed. I wear my PFD always, so if the boat never came back, I'd make it to shore or the searchers could find the body pretty easily.
I have some OMC products that do not have Kill switches. I'll have to adapt a similar Toggle method for them.
I never use it in the 26 footer, and always use it on the inflatable...
There isn't one on my boat to wear, and with my boat set up the way it is (fully enclosed pilothouse), if I fall out of it while driving, there are bigger problems to address :)
Tim
Thud, you can buy aftermarket kill switches; the ones I've installed would work on either an inboard OR an outboard, depending on how they're wired. And it's no problem to add a few feet to the lanyard if it tends to be too short.
Yes sir, in my Boatfix catalog (thanks Muddkatt) I found some and I'll have to see how to wire it in.
You should see the condition of my Lanyard now. Its killed by the sun and will have to be replaced soon. And it WILL be a lot longer when the new one gets here.
