Kneeboarding
  • Thread starter Thread starter blouderback
  • Start date Start date
B
blouderback
Guest
I just received the kneeboard I ordered the other day. It was a freebie from a frequent customer program and it doesn't have the hydro-hook or aquatic-hook on it. Never having kneeboarded before, what tips and tricks do you all have?
1. Easiest way for a fat load like me (6'0", 250lbs) to get up on it?
2. Easiest way for the kids to get up (10 YO boy, 6 YO girl)?
3. Is the hook a necessity?
4. Best practices for the driver to aid in getting up?
one tip i can give you is to stay AWAY from anchored boats... well away... there is nothign worst than some yahoo circling around pulling a kneeboarder... watch your wake, if it affects anyone... move away.
One more thing, do you think I really need a tower, or can we still have a pretty good amount of fun using the standard transom mounted ski hook?
Your call Bob....I've seen and been with both and people seem to always have fun. If you want to go pro...then I think a tower would become a must have deal.
Have fun...boat safe and with courtesy...Stan
Bob,
People were kneeboarding long before towers had been invented. The main advantage of a tower is that it aids in lift when jumping and keeps your ski rope up out of the water reducing the splash you take in your face. I'm not sure what the "hooks" you refer to are, but they are certainly not necessary for learning beginning kneeboarding.
As for teaching the kids to get up .... let them practice on land before taking them out. Loosen the leg strap up, have them lay on the board on their stomach with their arms bent a little and their elbows at the front of the padded area. Then have them "hop" up onto their knees. Once they have this movement down, take them out on the lake and just tow them around slowly behind the boat while laying on their stomach to get used to the tension. When they are ready to try getting up, you'll start off quicker and as soon as the board starts to plane (almost immediately) they will jump up. Kids will pick up on it quickly.
For you to learn, I would suggest placing your elbows on the smooth portion of the board just forward of the padded area to start. This helps to hold the board in place as you are getting up. Your timing will be much more critical, if you wait too long there will be too much tension for you to hop up and if you try to hop too early you'll have the same problem. It isn't real difficult, but will take some practice. I'm sending you a PM with my detailed instructions for an adult, let me know if they are helpful.
Bob, do your best to avoid whiplash. If you jump a wake and the rope pulls you too far forward into a situation where you're going to crash head first, let go of the rope. Don't ask me how I know. Also, if you're over 40 years of age, a kneeboard is not your friend. Again, don't ask me how I know. By the way, you'll never see me on a kneeboard again.
MardiGrasTexan
I'm a very young 43. I feel like a 22 year old. Unfortunately, I look like a 50 year old.
my stomach is hurting just thinking about kneeboarding. imagine, you're being dragged through the water. your elbows and shoulders are on the board but your legs are dragging behind, under the board of course. the boat will be going fairly slow but you need the water resistance from going faster. with the speed, your legs have more resistance against them and guess where they need to go? yup, you have to pull them up with your 43 yr old stomach muscles while balancing yourself with your shoulders/elbows AND holding on to the rope. the next fun part is inching your legs forward on the kneeboard into position so you can get comfortable and in the right spot on the board without losing balance or the rope. ahh, the memories. oh, the sore stomach.
can you trade it in on a wakeboard? i'm obviously a little partial but kneeboards should be called kneecrushers. i can't sit on land for very long with my legs bent under like that, it's no easier on the water. your kids will probably want to get a wakeboard eventually anyway. standing on a wakeboard is alot easier on your body although there are still ways to get some pain.
whatever you ride, beware getting dragged over your lead edge by the boat...smack!
10 and 6 year olds are so light, it takes very little effort for them to get up. get them in the right position, take it easy on the throttle, and the water should just left them right up.
It's easy stuff. Use a regular ski rope and handle, put the rope's Vee over the tip of the board, elbows where your knees eventually go - hold the handle like with hands facing eachother. As boat picks up speed use your dagling legs to keep straight and level, curl the handle (like curling weights - use bicepts) to pull yourself forward and put your knees where your elbows are...then put strap accross your thighs - fun!
Foots method is what I used. One thing I would add is after you are going, pull the handle into your belly button and lean back slightly when going over waves. This will keep the nose of the board up and prevent the board from submarining.
eric
Well, I'm a very young 41. Kneeboarding isn't difficult at all....just watch your landing, as you are straped to the board.
MardiGrasTexan
MardiGrasTexan
LOL.....Nor me on a tube again...don't ask me how I know....
Thanks MardiGrasTexan:) I relate all to well to your post..Stan
If you have enuff power you can start off on knee board on youre knees.I have pulled up a 250 pound guy. But we had a v8 on a 16 foot speed boat
Estimator, ever get down to Texoma?
MardiGrasTexan
Yes Sir! A friend striper fished there this past weekend. (limited out-as usual) I am tempted to bring the boat that way for a few days (my wife has not been on Texoma-I spent many weekends there as a kid)before taking her to Eufaula for the summer.
Will your Kneeboarding be done in the water, or in a tub of Jello??
Sorry Bob...I couldn't resist..
oh and I forgot to mention...when you start trying to jump wake to wake you will learn two words "FACE PLANT" but it is way fun!
