I went on an overnight "test run" prior to a week long trip in a couple weeks. The boat hadn't left the dock since Fall and the oil needed to be warmed so it could be changed.
On the return, a couple thousand yards from the marina, and after calling for assistance, I heard a warning beeping (I was on the flybridge). I looked at the warning lights and none were on. I looked at the gauges and they were normal. I looked at the depth sounder and had plenty of water depth. The alarm stopped then started again in a few seconds.
I decided to go on in and dock the boat. When I came down from the flybridge, I saw water streaming out the bilge pump thru hull. I asked the dockhand to stand by in case we needed to head for the horseshoe and haulout.
I went into the saloon and lifted the floor hatch and observed about six inches of water in the center bilge (no pump under the engine). Water in the center compartment floods into the aft compartment and was being pumped out.
I could see water streaming down the AC strainer but then I could see that it was coming through a limber hole from the compartment where the water heater and some of the plunmbing is located. I grabbed a handfull and tasted it. Fresh water. OK, now an "emergency" is downgraded to a "problem".
I turned off the water pressure switch (pump) and thanked the dockhand.
I got a flashlight and saw that a water line had blown out of a connector. An easy fix except for getting rid of fifty gallons or so of water that is where it shouldn't be.
Lesson for me: Recognize the difference between the high water alarm and the other alarms. Consider adding a light to the alarm circuit.
Lesson for everyone: Know your boat. Know it well. Know where everything is and what it does. Know how to turn it off if necessary. And remain calm.
