Kohler 20kw
Sam92881
New member
My marine generator is not pushing enough water through the muffler!! I replace the row water pump I clean the heat exchanger I flush with water hose and i started the generator is still not enough water.
What else can I look for
Can everyone out there can Gide me in the right direction to fix this problem
Excuse my spelling.
Thank you.
Sam.cardenas
How did you clean the heat exchanger? Did you just use water? Circulating a mix of water and barnacle buster may be needed to get rid of deposits.
Also, did you open the inlet side of the heat exchanger and check for impeller pieces?
I assume you cleaned and the sea strainer but you could also have a blockage outside at the thru hull. Growth or things like a plastic bag
Finally make sure you don’t have a suction leak between the thru hull and the water pump.
If the pump was replaced, did you open up the old pump and see missing impeller vanes? Was the replcaement pump new or rebuilt? There isn't much to add after Pascal's update.
