Anyone for fried batteries?
Last December I trickle charged both batteries fully. Today (after powering up the seat to get to the engine compartment) when placing the clamp on the positive on battery 1, I noticed more sparking than usual. Then, when hooked up, the gauge on the charger registered zero, which it has never done before. It was then I noticed the positive post on battery 2 had melted into a pool of what looked like solder and was completely disconnected from the cable. Upon further inspection of battery 1, I noticed a small pool of "solder" at the base of the positive pole.
I put the volt meter on battery 1 and it read 12 volts. I put the meter on battery 2 and the needle went backwards. I also found that the Perko dual-battery switch moved freely to position 1 and Both, but would not move to 2.
Unfortunately I cannot be certain of what actually is battery 1 and battery 2. They both worked fine so I never bothered to actually figure out which was which. One was new in 2001 and the other about 2005.
Replacing both batteries would be financially painful but the big question is- what the heck happened and how do I prevent a repeat performance. Help!
Let me know if you need additional info...
thanks, Peter
thanks, Peter
