Leaking side windows (sliding type)
Grand Larsony
The side windows on my 1989 Larson 25' express are leaking. Has anyone dealt with this and if so what are my options?
Water seems to be running down the glass and back up the inside via the deteriorated "fuzzy plastic tracks". I've cleared out the external weep holes and recaulkedrebedded the perimiter seal (after removing the entire unit).
I think I need some parts - e.g. new sliding tracks - but I'm not sure if it's reasonably possible to disassemble the entire window unit.
Any input would be greatly appreciated. I don't have part numbers but will look more closely today and possibly post pix. Have contacted Larson but no response just yet.
Thanks !!!!
Sliding window channel is readily available. I don't know if 1989 boats used the same stuff that 1950's boats did, but window channel is sold in 8' lengths. U-shaped stainless channel with plastic slide strip on the bottom and fuzzy water seal on the inside walls. I've done window rebuilds and glass replacement on our boat. Time consuming but not difficult.
http://www.boatfix.com/catalog/365.pdf
I had the same problem and went through a process of opening outside drain holes etc with no fix results. Then I discovered the cause by holding a hose against the sliding window. . . starting at the bottom and moving up. Unbelievably the water was coming in through the small window lock which was held and sealed in the glass by a small o-ring which needed replacing.
I guy I knew had this problem on his 1979 Bayliner Victoria. If he was out in the rain, the port cabin window would leak inside and soak the carpeted bulkhead. He cleaned and caulked and weather stripped and cussed! Finally he drilled three small holes into the aluminum frame at the aft end. These holes only went through the outside section. That window never leaked again!
Thanks guys - I'll pull it this weekend and see what I can do. The problem, I think, will be disassembling the entire unit so I can replace the tracks on which the glass slides. I've definitely ruled out a perimiter andor weep hole as the source of problem. Will check the thru-glass holes as suggested above. Again, thanks - this is a GREAT forum !!!
Good luck. Do the disassembly carefully: noting where the pieces go and how they were originally bedded (sealed). Getting everything back together the same way and properly sealed is the trick.
