Leaking trim tab pump
rinker1
Here is an email that I sent to Bennett Marine on a problem with trim tab pump. I thought I would ask the board for input as well.
Hello:
I have a 1999 Carver 326 with your trim tabs on it. I have only owned the boat since 10/2006 so I am learning the systems and fixing small problems as I find them.
I am having trouble with the hydraulic trim tab pump leaking. When the tabs are lowered all the way down the hydraulic pump leaks behind the plastic pump face. It leaks on the top behind the two brass fittings that are attached to the pump face. I took the pump home and disassembled the unit and could find no obvious problems. I went ahead and replaced the three o-rings in pump face. When I re-installed the unit the pump would not do anything! By trial and error I loosened the pump face screws slightly and the pump began working fine but the leak still persists.
Please help me figure this problem out as it makes a terrible mess in the bilge. I'm not so sure the O-rings that I purchased are the correct spec as they came from Napa. I made a visual match so I could be wrong. Can the brass fittings in the pump be tightend to seal the o-rings better?
Bennett is one of the best in marine when it comes to customer service. I wouldn't be surprised if they just sent you another unit and asked for the old one back, no charge. I used to deal with Tom McGow, who monitored this board. Don't know if he still does.
Bennett is send me a new pump face and oem o-rings out at no-charge. That is pretty cool as I am the 3rd owner of a 1999 model boat. Man that is customer service!
