Leaky bimini
hamster
This past weekend, we got caught in a horrific storm at the mouth of the Sassafras and Chesapeake Bay. While we were trying to figure out our next move, I noticed the bimini was generally damp on the underside and in some places leaking. What do you use to seal the camper tops on your boats? Is there a brand better than others? How often do you seal the camper cover? BTW, we did manage to get to port after things settled down. It was scary at times but I guess the key to getting through that event was clear thinking, patience and not panic.
Hi Joe,
I'm just a bit south of you off Rock Creek. Glad you survived the storm. Was it this past Sunday? We were in Rock Hall on the hook and left at 8am to beat the storms back to the western shore.
Your canvas "problem" has an easy solution: waterproofing (Fabric Guard). I always use 303 (recommended by Sunbrella). BoatFix sells it in a 16oz spray bottle that should provide you with about half a dozen treatments:
http://www.boatfix.com/bypage2index.asp?page=766 (second from bottom as the bottom is a quart of it)
I treat my 5 year old sunbrella top when it leaks or when I have to clean it. Otherwise, I leave it alone.
I also use 303. Easy to use and works well every time.
If it's leaking at the seams, try a wax stick. You can usually find them in camping supply places for a lot less than marine supply stores.
I thought the title of this thread was "leaky bikini."
Oh, well.
G
303 every year for me. One trick I use is to pour 303 in a garden spary and apply it that way. I found the tripper spray was difficult to get an even coat across the 13' beam.
There is a product for tents called "plastiseam".
Thanks for the responses. I'll be heading down tomorrow to clean the camper canvas with Woolite and hopefully, it will be dry later to use the 303. Great idea on the pump sprayer, Fountain. I'll have to take one down and try it.
Mixman, it was this past Sunday. I was told we had up to 50 mph winds. I know the winds were high by the way the boat was reacting but not sure if it was 50 mph or not.
Gcolton - I didn't notice if the seams were leaking. There was too much going on at the time but I think it's just the canvas since it was damp in a lot of places. I'll have to check that out after I use the 303.
Thanks again everyone.
Joe,
There were certainly some bad storms that day. I do normally get up at 8am on weekends (too darn much earlier on weekenday!), but to get underway at that time when I wanted a nice breakfast shows what weather was coming.
I can't say if this is right behavior or not, but I never clean my canvas (Sunbrella). I rinse it every so often with water, but it's up in the elements 363 days a year here in MD (down 1 day when hauling to FL each year and one day back...strike that, 303 days in MD and 30 days in FL and Bahamas :-). I just wait until it leaks and then I hit it with the 303. The "rumor" is that dirt helps to seal the fabric to a point. Again, I'm not real sure how true all this is, but it's been 5 years and things are holding up rather well.
