Hi guys,
Under the guise of don't ask questions if you don't want to get beat up, I'm gonna ask a question. I recently seemed to have corrected a trim problem on my 1971 23ft Winner. It now pops up nicely on plane but does a distict tilt to starboard. I've got the weight pretty well distributed on board. One battery on each side. Small fridge & sink on starboard, tools & equipment on port. Helm is on starboard, I weigh 200lbs. I disassembled the drive & refinished it. It is an OMC electric shift with GM V6. OMC haters can stop reading here. The rudder is on center of mounting plate and allows for adjustment. Could this be the issue, or do I need to always have the starboard trim tab down a bit to correct this leaning issue. It is more than a bit disconcerting. Thanks in advance for your help.
