LED light bulbs
Big Bliss
Okay, I have 30 lights in the ceiling that have the G4 halogen bulbs in them, suuuuuuuuuuuper hot...
I am searching the web far and wide and cannot find any LED replacement bulbs. I found one but that is only 1 Watt and barely glows. I bought a dozen of different style MR11 type LEDs, they fit the socket and are bright enough but will not fit the lamp housing
Did anybody find any LED G4 replacement bulbs?
Not looking for this style:
as my light fitures require the bulb to have the connectors in the center and not on the side. The flat round ones with multiple LED diods are symply too wide and the connector not long enough.
Have you checked with the mfg? Maybe they haven't started marketing replacements yet. I found that to be the case when I first bought my inflatable PFD. I had to wait a few months to get the replacement kit. Now they are widely available.
I used the last of the 3 you show. I had to rework the fixtures with a dremel. They are just as bright as what I pulled out Dominic. If you want I have about 20 left over I will give you 4 or 5 if you want to try them or see if your fixtures will accept them.
Google "Everbright LED". Select "LED Bi-pin based" on the left menu.
We replaced ALL the lights on board with the bottom two (in Warm White) but I also want to try the E160333 ones too.
hard to justify the cost of LEDs even if they're a little cooler. I found Xenon G4s which looks exactly like the halogen (same size and same light color) and pay only $ 1.20 each.
Check out "super bright leds" (all one word, dot com). From what you described, you want the G4B-xWHP4-D. I just used these for the two reading lights in my mid-cabin (center connection, not side connection) and they worked great. They are $11.95 each. I've purchased a bunch of LEDs from this site and am happy with their service.
-Brian
2001 Regal 2960
I put those in several of the reading lights on my Regal. I used the disk lights in the overheads and they worked great but the light above should do what you want BB. $16.95 at superbrightled
BTW - the halogens in my boat run around 225 degrees and the LED's were around 100-110
how bright are they? LEDs dont' work with dimmers, do they?
You will also cut the power consumption by about 80% plus, combined with less heat generated that is worth the money. Most LEDs have 10,000 of burn hours, most likely you will never need to replace any of them. Yeah, most LED vendors have dimmers ready. Yachtlights is one of them.
yeah, well... i'm not ready to buy the 10 000 burn hours just yet, when i just discovered an expensive LED transom light with 75% of the LEDs out after only 6 months!
If that is the case Pascal contact the manufacture. They should replace it. I installed a 150amp DC Power line filter on my primary 12 VDC buss and that has really tamed down strange intermitant problems I had with lights, entertainment equipment and chart plotters.
these LED lights have a regulated power supply so power isnt' an issue. Unfortunately, that specific fixture can't be removed in water and we're not going to haul out just for that. (this is why i strongly believe it is plain stupid to mount lights that can't be replaced in water; the other two were installed so that they can be removed and replaced in the water.)
Sorry to hear, hope it wasn't OceanLED.
The light above is every bit as bright as the halogens they replaced. Superbright also has the disk lights with 4, 6 or 10 LEDS. I replaced the 4 lights over the salon table with the 6 LED version because the halogens were too bright for us. These seem perfect. The 10's would have been equal IMO.
Superbright sells their LED replacements in 2 color temps. A cool white which is 7000-8500 degree which we find too blue and a warm white at 3100 degrees which is very close to the 3000 degrees of normal incandescent lights. We went with the 3100 degree lights.
As for dimming since these particular light replacement bulbs are rated to operate over a range of 8-30 volts I'd have to assume they have built in regulation and will not work with dimmers. (They'll operate but won't dim) We don't have dimmers on the boat so not an issue for us.
Big Bliss,
I just upgraded my G4's in my cabin to LED lights. I used the ones from Dr. LED they are super bright and was amazed of the output of this single LED. Their technology is high flux LED's so their 1 watt version put out the same as a 30 watt bulb. They are a tad pricey, but in my opinion well worth it. What I also noticed is the light is a tad whiter. Do a google search for Dr. LED.
I sent this to Dominic directly, but for the benefit of others I replaced all my G4's with these:
Found at: http://autolumination.com/2pin.htm
At $7.99 each, it wasn't very painful. I also replaced all my MR16's with LEDs as well as the anchor light. I went from a 15 amp draw for lights down to a little over 2 amps.
Thanks Mixman, I just ordered 10 of those bulbs to try out in my salon lights.
Cool. I hope you they work well for you.
