LED Navigation Lights
I replaced every bulb on my boat with LED last year. It cost me a couple hundred dollars but I am pleased with the results. I went with the Perko white all around which was the most costly upgrade.But it is far superior to any incandescent. For the nav lights I just replaced the bulb with 360 degree white LED's.They are just about the same look as the incandescents when you put them behind a colored lens.All my cabin lights I used various MR11 and G4 bipins clusters. I did the cockpit and arch with bayonets and festoons and even did the gauges and installed some under the swim platform for a neat cool factor. I did stick with a couple of fluorescent down below thourgh.The power saving is truly amazing.
If you solder your connections propley and use high quality heat shrink, your will not any corroson problems. I bought a set of stainless led side marker lamps from boater world and I think they were only about $80.
