Les PC-Planner Navman
Ga_Compounder
Does boat fix have the PC-Planner for the Navman? Will this also work with the Northstar M121?
Chuck
Les, I sent you a PM over a week ago. I need an MMC card to improve my Lowrance iFinder H2O. I'm pretty sure BoatFix sells these, but my search has been fruitless. Can you tell me what I should order?
BTW---MapCreate really sucks! I wish I had not purchased a Lowrance GPS again. If I had it to do over again, I would purchase a Garmin.......
Flutterby go to your local Walmart or any big box store. The MMC is virtually identical to the SD card which is used in many cameras. SD cares work fine in the Lowrance products. The Create a maps are NOT marine maps. You need to either buy the Lowrance Nautipath chart chip (all NOAA charts of the US for $99, or any Navionics charts appropiate for your area. From the Lowrance web site: "Compatible with optional plug-&-play Lowrance FreedomMaps™, Fishing Hot Spots® Pro, LakeMaster® ProMaps, NauticPath™, and Navionics® electronic charts"
I would not buy a Lowrance i finder H20 as a primary chart plotter for a boat--dinghy or back up--OK, but the screen is too small. It is a very good hand held GPS. I have used the Create a map Topo maps both on a LCX 26 C HD, for locating streets, and topo features, as well as some lake navigation--but use the Navionics lake charts for detailed lake and river navigation.
There are only two differences between the MMC and SD cards--the SD has a lock which will prevent erasure, and it has 9 contacts, whereas the MMC has no lock and only 7 contacts. They are the same size, thickness and configuration. The SD is a slightly newer and an improvement on the MMC (both developed by SanDisk) So far I have found that in Lowrance and Magellan chart plotters the SD card seems to always work for me. The SD cards seem to be much more commonly available.
Thanks for your good advise and info! I've placed an order for the NautiPath card. And according to Lowrance, MMC and SD are interchangeable. I've updated my software, now all I need is charting s/w.
Bob, my previous Lowrance used MapCreate and was just fine for my use in the Delta. But now I find that 95% of the detail is missing in my new Lowrance. I am so disappointed! Now I'm having to spend nearly $100 to get the information that I need/want. Lowrance has lost a customer. I will never purchase a product from them again!
I'm taking a cruise down bay to SF in Sep; I'll see how I like the upgraded s/w on that trip!
Ga-Compunder - Did anyone ever answer the original post on this thread?
Flutterby - The MapCreate software works well for finding a McDonalds on land, but simply does not have much marine detail. It has not changed, so I don't know how your previous unit could have had very good marine detail. I have had several Lowrance units over the years, and all have required additional maps to get good marine detail. Some of my maps include a C-Map for Lake Michigan on an older unit, a fishing hot-spots map for small inland lakes, and recently a Nauticpath map for Lake Michigan that has fantastic detail (on-par with the C-Map). Lowrance offers a wide variety of affordable mapping options. The Nauticpath map in particular is an outstanding bargain!
Well, Nibbs, I had a prior Lowrance GlobalMap 100 that did just fine for my needs. It used MapCreate and the detail worked fine in the delta and on the road. I'm not expecting a ChartPlotter quality, but I did expect to have similar quality from MapCreate 7.x that I had on the old one. The reason I purchased another Lowrance was because I was perfectly satisfied with the one I had. Enough said.
