Life Rafts
divedaddy
Anyone have any advice on a new life-raft? I want to add a coastal life raft to our Sundancer 330. The normal family load is two adults and three kids - currently ages 7,6 and 2. I am leaning toward a Winslow Super-Light Coastal model, valise packed. From everything I have been able to find they seem like a good raft and I like the light-weight design so the Admiral can readily move and handle it if needed.
Any suggestions, input, pro's or con's on the Winslow rafts or other models will be greatly appreciated.
I am not familiar with them, but I would tell you to look for something that is sealed in an air-tight compartment and does not require annual servicing.
I have a Switlik hat came on my new to me boat and I am finding out that it requires annual service to the tune of around $650 a year.
Boight a Winslow coastal valise one year ago; we initially we looking for a four person raft; but once we looked at how much space a 4 person raft provided; as well as the weight; valise size and cost we opted for the 8 man on our Sundancer 310. At the time we thought that the three best raft companies were Winslow, Switlik, and Revere. Take a look at the how many square feet the raft allows for each of the "people" in the 2,4,8 man rafts. I believe that the SOLAS regs only require like 2.2 square/ft per person...just food for thought.
NB. If you get the raft vacuum packed it increase the duration required in between services.
I am waiting for delivery on my Winslow 6-man raft. Purchased at the NY boat show. I like the light weight and the vacuum packing. it's well designed and well equipped. By the way, you might get better pricing by telling them you saw it at the Miami boat show.
I own a 6 man Winslow offshore valise model. 3yrs between repacking.
So far no need to use it so I can tell you how it works.
I'm hoping I never get the chance to test it.
Jonathan
I have the 6 man Winslow offshore valise model also. When I was shopping everything I read gave them top ratings. I also liked the idea that it was light enough that in an emergency it could be quickly moved into position and deployed. I previously had a 6 man raft that weighed 110 lbs in a valise, it was very awkward and moving it was a 2 man operation.
We are also of the Winslow family and had ours repacked for the first this yr. They were very good about handling all needs, and they payed shipping one way and you payed return. As the others, I haven't had to use it and hope not to, however as John mentioned they are rated pretty high. We are also a 6 offshore!
Thanks everyone for the feedback !
Like several of you said everything I find speaks very well for Winslow. The weight factor is a real plus. I will check the size - I was thinking 6 person but 8 might be the sensible thing. Where we are it would be extremely unusual to be more than one hour from CG, if nobody else showed up. I hope I'm like Jonathan and never find out how it works, but with three little ones I want a platform to get onto just in case.
Probably doesn't need to be said, but a GPS enabled EPIRB should also be standard equipment. It will keep that "one hour from CG" realistic.
I put one of the small colerful looking ACR epirbs in my raft. Plus I have a large epirb on the boat.
It's a good idea.
Jonathan
The recent issue of "Practical Sailor" has an overview--but no ratings--of life rafts that meet new international standards. Their 2003 tests selected Winslow Ocean Pro. The current article does cover generalities like relative weight, watertightness, deployment, boarding ease, etc. of such models as Elliot 6-Solas, Switlik MD-3 and SAR-MKII, Viking and Zodiac.
Send me your address and I will send you a photocopy of the article if you are interested.
Laabbott**cushing.org.
I think it was the Viking raft that had such a sever rubber smell that if the ocean didn't kill you, the smell for this raft might!
The Winslow isn't made from rubber so the raft had really no smell to it.
That was one reason why I picked it.
Jonathan
Right Sea Gull, GPS EPIRB. Got one - new ACR Global Fix.
Curious - how many have replaced the EPIRBS to keep up with the reg changes?
Again, many thanks for all the tips. I ordered yesterday - 8 man canopied coastal, vacuum packed, with inflatable floor. I asked about boat show pricing and got a nice discount (thanks Sea Gull!).
