You are limited to only one type of boat or perhaps two, if you want the range and don't want to go with a motor sailor. One is the traditional "Trawler", or an ocean going Cat. All of my ocean cruising has been sailboats, motorsailors and trawlers. A good motor sailing boat is the best of the lot. We cruised over 40,000 miles in a 62 foot motorsailor, and over 35,000 miles in a Cal 46--both are older but well built boats, which will sail at 150 to 200 miles a day, or power at 150 to 200 miles a day. Just within the last few days, 3 Nordhavn's crossed the Atlantic. The fuel "mileage" was extremely disappointing--it was from 1.2 to 1.6 miles a gallon. We got 6 miles a gallon on both of the motor sailors--at about the same speed--and boats which were more seaworthy. (Then add in the sails--where we crossed the Atlantic with only 50 galllons of fuel used for the generator, plus maneuvering at each end of the voyage)--same for trips to Hawaii and the S. Pacific.--anywhere you have the tradewinds.
There are very few motor boats which have the range (fuel capacity) to do the long runs)
A friend is currently doing a circumnavigation on a Choy Lee 50-and did a trip to the Gallapagos with no problems from Equidor and then up to Mexico. (He carries 1600 gallons of diesel, and runs at 6 knots) There are relitatively few boats which are true long range cruisers (at least 2500 mile range). Hatteras made a 42, a 48 and a 58. Kadey Krogen made a 42 and 48, with a 44 currently in production. Nordhavn makes a number, Selene makes a number, Marlow is at the upper end size wise.
Choey Lee made a 50/52, a 58 and a 61/66 Long Range Cruiser. Defever has designed a few Long Range Cruisers--but most are marginal on the range that you would need for the Galapagos.
There are a couple of resources you need to tap--the Passagemaker forum, the Trawlers and Trawlering Forum, the Passage making under power forum and Seven Seas Cruising Association (although primarly a sailing organization, lots of good information there). Passagemaker magazine has some good articles, but remember that much behind the gloss is selling products.
There are also a number of skills you will need to master: weather prediction and routing, seamanship and heavy weather boating, diesel mechanics, electrical systems--both high voltage AC and DC systems, watermakers, navigation--not just chart plotting, use of radar, etc.
The other type of motor vessel you might consider is a power cat. There are a very few which have the range, and even they do not have the range to go more than a displacement (or trawler like speed)--of 6 to 8 knots if you want to cross oceans. Whirlwind IV came on its own bottom from New Zealand to the West coast US and around to the East Coast and to the Great Lakes. Malcom Tennant's web site has a goodly amount of information on both power and sailing cats.
I think that you are missing a lot by not wanting to be involved in sailing-- Yes, you have to learn some new skill sets for sailing, but if you truely want to cross oceans or even go to the Caribbean, you will have to learn a lot of skill sets. Passagemaking is far more than pushing a few buttons and casting off.
The other mind set you may want to re-explore is single handing a boat on a passage. Yes, people do it, but there is a significant risk. The risks are primarly of being run down by commercial shipping or fishing vessels. There is also the risk of fatigue and that of not being able to do repairs. There is also the confusion and dillusion which often comes with fatigue and no other people to interact with.
If you have a system on a passagemaking boat, you need to either be able to repair it, or do without it.
I would also re-consider the age of the boat--there are a lot of very good older boats which are very capable of passagemaking. For example the Nordhavn 46 will run in the $440,000 range, and the newer 47 will cost in the million dollar range. If you want to spend considerably less than this the next step down, that I can think of, is one of the Hatteras 48's for $248,000, or a Choey Lee 49/50 for $250,000. On the other hand, a Cal 46 is an excellent older motor sailor, and probably propornately to the number built have the most offshore miles for 80 to 100,000 dollars. There are a number of even smaller pilothouse boats, which will make the voyages safely, but probably not sail as well. Yes, there are sailing cats which are quite capable of ocean passages, but for single handing, I would really suggest against that type of vessel.
