Thanks for the replies guys. To clarify I do in fact have two separate battery banks. The problem has two parts: 1. Battery One has constant load on it from the bilge pumps, mercathode, fire and CO detectors. If I leave the boat boat unattended for 2-3 weeks there is enough draw to deep discharge the battery. As you know, a few cycles of deep discharge and the battery is toast. 2. The simple solution is to plug in the battery charger when I'm going to be away for a bit. This is what I usually do, but there's a weird wrinkle to this story. My boat does not have shore power, so to run my charger I have to plug it into the 120v plug on the pedestal. So far so good, but what I discovered is that the 120v receptacle is on the same breaker as the photosensor night lights. The dock owner, to save a few pennies, has been turning off every other night light. Guess whose usually gets turned off my accident? No one else has a problem with him doing that because the 30 and 50 amp service is on a different breaker.
