Loose steering
JERUIZ
Sirs,
I have an issue with my hydraulic steering when cruising in following seas. It appears that I have to be constantly adjusting the steering position to keep the boat straight. I have seen myself zig-zagging in following seas and it does not happens in head on seas. It is giving me a feeling of a very loose steering having the swells take easy control of the boat.
I own a Hydrocat power catamaran with twin Yamaha 225 HP four strokes mounted on Armstrong brackets. The steering is Teleflex with Hynautic 5741 system on each engine with no mechanical tie bar.
I have a friend that told me that something is wrong with the steering but I'm not sure since it runs excellent on head on seas.
Please, any advise will be greatly appreciated.
a) Bleed the steering. It could be air in the system. Or not. But check anyway...
b) Many boats truly hate following or following quarter seas and become nearly uncontrolable.
Since you did not indicate if this has always been an issue or if this is a "new" issue, it is more difficult to choose (a) or (b). I haven't run cats, so I can't say, but I do know that my boat did not like certain sea directions and "tacking" downwind was sometimes the cure.
Thanks for your advise and prompt reply. I bought the boat September 2006 and I had not felt this before with the exception of yesterday on a three hour cruising ride with the family. I will definitely try the bleeding of the system.
If anybody knows how the Hydrocat 300X or any other catamaran behaves on following seas please let me know. My previous boat experiences had been on single V-hulls.
Appreciated
My previous boat was
did you try to adjust trim angles ? trim tabs up ? move weight aft ?
if you had a steering issue, it woudl feel sloppy all the time. with outboards you can see if the engines react right away to steering inputs.
Modern hydraulic steering systems are not like the old "bleed" systems, especially in the example of the Hynautic hydraulic steering system which is an already pressurized system.
Therefore, unless there is a fluid leak in your steering system, I doubt that your problem is a steering system malfunction. I agree with Pascal that if it were the steering system per se, it would feel sloppy all the time.
I think that it is more likely the speed at which you were traveling compared to the following sea conditions in which you were operating.
Having said that, what speed were you making and under what sea conditions?
I was cruising rb2@gr5t 20 to 22 MPH moving west. In my area (Atlantic) the swells almost always run from east to west. Yesterday we had three to four foot swells.
By the way, the power cat do not have trim tabs.
Your feedback is greatly appreciated. Thanks to all!
It sounds as if you were moving slightly slower than were the seas, that is, the seas were passing you thereby causing the problem that you have described. Were the seas directly behind you?, or were they coming slightly from one side or from the other?.
Even after this discussion has ended, you still may wish to perform some steering system check-up just to be sure that there is not something awry.
It is very difficult to diagnose a problem such as this without some hands-on experimenting.
"Modern hydraulic steering systems are not like the old "bleed" systems"
I'm not doubting your statement, but my boat, a 2000/2001 had hydraulic steering and bleeding was required. I agree that there are other types.
But, I still think that is a sea type vs hull type issue. The good news is that the fix is free. But the fix is a work around, in that you have now discovered an area of the "envelope" where the boat does not perform at it's best ( very mixed blessing. Good to know, and good to avoid. ) All boats have handling quirks, and this sounds like one. ( It is also a very common one, so do not feel singled out. Following and following quarter seas are difficult for almost all boats with a "straight up transom" ) I was unaware that the cats might exhibit this characteristic, however.
I would think the sharp bows of a catamaran would be more susceptible to yawing in a following sea; if you can trim them up it would probably help. Maybe just slow down. I wouldn't be impressed with the results if one dug in at 20+ mph.
To give you all an idea the way it felt, it was like surfing the wave for a while in a straight line and all of the sudden the boat felt like been forced to change the course requiring to steer into course again.
To Bill's point the sea was coming directly from behind. I will definitely have the steering system check and will do a faster test run at different angles to see how it behaves. All of your comments had provided good feedback to start testing. It could be the hull reaction to following seas at slow speed.
Thanks to all
