Loran-C (the current system) is defnitely NOT as accurate as modern GPS. I have firsthand experience regarding this (differences in position of almost 10 miles). What Loran is good at is getting you back to the same spot every time (repeatability). Commercial fishermen, in particular, have capitalized on this for finding their gear. Basically, it has an error, but the error is relatively constant and if you can figure it out, you can offset your fixes to be more acurate, but what's the point when GPS is simpler, more reliable and works anywhere. A lot of large vessels these days do not have a Loran reciver or don't regularly use it (my last two ships didn't have it at all), as GPS has pretty much completely taken over.
As for Celestial Navigation, it indeed still is a BIG part of the USCG license exam for deck officers. I'm not sure at what stage it "kicks in" (apparently not at the 100 ton if it's not on Any Oceans), but a 3/M Unlimited definitely requires it (the 3/M license I get also counts as a 100 ton Master). Celestial is really not very difficult (rather, it's time consuming and only accurate up to a point), but really is only necessary for deep-ocean sailing. To become proficient enough to be accurate enough to use it closer in is impractical and unnecessary. If you are within sight of land (either visually or by radar), you should be using terrestrial navigation methods (of course, doing celestial for practice or for fun is different). Most celestial operations carried out on merchant ships are for checking the accuracy of the gyro compass (azimuths, amplitudes etc). Still, it's a lot of fun to learn and it's pretty amazing when you work it all out and then compare it to a GPS fix.
Radioactive,
The only manufacturer I'm aware of that up until recently made a unit, was Furuno (LC90Mk2). It is no longer made.
