Doc,
I have the Magma Catalina, but I assume the principle is the same.
My spark was very weak too...First, try cleaning the electrode light sandpaper, and ensuring the insulator has no grease on it.
With mine, some grease had run down the ignitor wire, and was shorting out the socket connector on the other side.
Be careful if you undo the Ignitor, it's not a self tapping screw, there is a nut on the other side, and it can fall down into the wall cavity never to be seen again. The only way I could remove the ignitor on the catalina was to remove the Gas Burner, and insert an offset long nose pliers thru the burner hole, grabbing the nut (but I still managed to drop it !)
Wayne
Larson 310 Cabrio
