Maintenance for Trailer
bmfesq
What type of maintenance is recommended for a trailer, ie., grease, lube, brakes etc.?
You just listed the maintenance in your question. Also, check the winch strap, safety chain, tire pressure, lug nut torque, lights, springs, rollers/bunks, brake lines. Repack the bearings every couple years...do it the right way, which is disassemble the hub, pull the inner and outer bearings and pack by hand...pack the hub as well. New grease seals will be required since removing the old ones will destroy them.
If tires are 5 or more years old, consider replacement if you hit the highways at all. Tom
Just to add to the suggestions already listed, check your trailer frame for stress cracks and broken welds at each bend point and each of the ribs both where they conect to the main frame and where they bend. If you find any, have a certified welder repair them, and concidering this is an '01, look into extra bracing. Check the fit of the hitch to the ball and if there is slack, you might be able to tighten it up and add grease to it befor winter storage to help prevent any rust............D.........
Lights, clean the connections and coat them with grease every year... If you have old drum brakes take them off while you are doing the bearings... grease, use lots of grease... grease everything in sight!
wash the salt water out of the springs everytime it comes out of the water.The salt gets between the leafs and causes them to bounce to much, and then causung them to break.Just had to replace the ones on my trailer, 3 axes 600.00 buck$.
