Depends greatly on the regular maintenance performed. If you accomplish all the required maintenance as required and maybe even extra maintenance if you run it hard a lot then 2000+ hours is not unheard of. This may be conservative.
Mine last ones went about 2500 hrs before being replaced/upgraded as running takeouts. They were starting to require more frequent minor repair issues by then. Oil changes had been between 50-100 hrs and changes on my new Crusaders are every 50 hrs running at least a couple hundred hrs /yr. Your mileage may vary.
