Marked anchor line?
inkblue
Do you mark or flag your anchor line so you know how much you've put out?
If, so, what do you use to mark it?
Thanks.
[:-viking]
No, I judge my scope by the angle of the line to the water. The narrower the angle from the point the line enters the water, the more scope is out. If the line is entering the water straight down, you are way underscoped! Works for me every time and I don't have to worry about counting marks while letting out scope.
i don't think you can reliably judge scope by angle... yeah, if its vertical, you'll know but otherwise it's hard to judge since wind will also affect the angle. in low wind, your rode will be near vertical... even when testing the set with engine, i dont' think you'll be able to tell between 5:1 or 6:1...
there are many ways to mark your rode... which works best also depends on you anchor. if you have a windlass controlled from the helm, you need to be able to see the markers from the helm. these little labels arent' going to work out.
to see the markers from the helm, i use paint marks... i like the KISS method, dont' see the need for cmplicated multicolored charts.... one short (5") paint mark per 25', one long (10") per 100'. this way when i see 3 shorts, i know i've got 75'... 1 long 1 short is 125... etc...
the downside of paint is that you have to touch it up regularly... every 6 months here (we acnhor every week end) but that's the only thing you'll see from the helm, especially at night.
I found some vinyl material slips that are marked in 25 ft increments that you just slip into the twist of the line at the proper interval. I've had them in the line for years and they need no maintenance. I've seen them in different boat supply stores.
Pascal, perhaps with your boat/rode setup, that would be the case. I believe you use an all chain rode?
I only have 6 ft of chain which helps to settle the anchor in place, but won't prevent it from sliding. Anyway, for my 22 ft boat, checking the angle before settling down with a cocktail works for me.
hey... if it works for you.. that's all that matters ! :-)
seabreeze, they're all over the place, every catalogue has them. i guess you could use regular electric tape or colored duck tape folded over thru the line... and place one strip per 25'... that would be visible from the helm and maybe longer lasting than paint...
Rode markers like these made by Medof fit right into the braid of 3-strand anchor line.
Color coded electrical shrink tubing works fine, too.
I have those inserts and they only work if I'm standing up at pulpit watching. I can't see a thing from my cockpit so when anchoring alone, I let some out with the windlass and then run up and pull the rest out by hand until I get to the mark I want. Then tie it off and run back to set the anchor. bummer.
I keep a rough measure as I lower the anchor and feed out the line -- one armspan equal to about 5 feet. Ugh, looking forward to a windlass or at least a bow roller! Hopefully later this year.
Anchoring alone can be a challenge on windy sloughs and rivers. No windlass on my boat, so it's all by hand on the bow. The trick is knowing how far you can drift before running aground and allowing time for trips between the helm and the bow.
I use liquid electrical tape. Every 20' I paint my rode plus I have 40' of 3/8th chain and have the chain marked 5' from the 66lb anchor so I know when to stop. I use a different color for each 100' of rode. Works great and we anchor out almost on a weekly basis in the summertime.
Pascal, even in calmer conditions, don't you find that it's best to slowly reverse away from the rode so you don't dump a pile of it on the sea floor?
i do use the engines, that's why i said that it's important to have markers you can see from the helm where i can control both the windlass and the engines.
and since we often anchor in a crowded harbor, it's even more critical to remain in control of the boat.
that said, unless it is dead calm (rare) i usually let the wind push the boat back and only use the engines to make sure the anchor is really holding. My FX55 has tremendous holding power in our bottom conditions but needs slow speed to set.
ok - I was trying to imagine a scenario when you'd be unable to judge by the angle of the scope. so you still COULD, you just prefer to use markings to be more exact... (I've never bothered to measure and mark the rode, and probably never will)
Paint is used on all chain by the navy on "boats" a tad larger than ours. It has worked well for years. I have seen colored cable ties used in place of the markers yzer pictures. Same effect and cheaper.
i dont like guessing... in the waters i usually anchor in, i know that when i drop 75' of chain, the anchor will set; almost guaranteed :-)... i'm kinda lazy, I hate having to haul out the anchor and try again because it didn't set right away and I'm now a little to close to another boat. But for day anchoring, plenty of room i guess looking at the angle works...
frankly, if you visualize or draw 7:1 or 5:1, i don't think you can really tell the difference, at least not 100% sure. and i like to sleep well at night, I don't want to wonder if i really have 5:1 or 7:1 when the winds picks up at 2am !
I use shallow anchorages that vary in depth from 7 to 30 ft. I never will hit two places in a row that have the same depth. Wind and current conditions will alter the line angle at a given scope. For me, line angle is useless for determining scope. Having marked rode on an estuary is the way to go. Sam Clemens knew all about it.
The anchor and ground tackle is a Danforth Standard 1300 anchor, 35' ft. of Acco 5/16" 3B chain, ACCO anchor rode swivel, Samson Pro-Set 3-Stranded Premium Anchor line (and markers). I have slept very well in winds gusting to 35 MPH. Wherever I drop anchor, all of the chain goes out.
just thinking with my keyboard here yzer, but if you can't determine the depth, knowing the amount of payout is useless, yet the angle would be indicative...
I'd have more chain if I could, but my windlass won't accept a combo of chain/line and I can't justify replacing a windlass that works perfectly. I've been waiting for 5 yrs for it to break, but it just keeps on ticking!!!
Yzer and I both boat in the same waters and each of us has been known to anchor out while alone. I've never had a problem with wind breaking out my anchor. And I've been in gusts to 40 while at anchor. But that darned seaweed that has been spreading around the delta will prevent my anchor from digging in and taking a set. Whenever I anchor overnight, I have out both bow and stern anchors, just because I sleep better!
When setting anchor, I'll get the depth of the anchoring spot with the sounder on the first pass. Then I drift from that spot to see what the wind and current are doing. On the second pass I'll drop anchor on the same spot and pay out enough rode as the boat drifts to get full scope (based on the depth sounding). Then I cleat off the rode. At this point, the boat usually slams to a stop as it drifts to the end of the line, but I'll back up on the engine just to make sure. After the anchor has soaked an hour or so, I'll pull in some rode if I want to. But that depends on the conditions and if the anchorage is shared.
Yeah, Flutter. I hear you on the invasive weeds! That has made it a lot harder to find decent anchorage under 8 ft of water or so. Second anchors (especially stern anchors) make me nervous. They can compromise the main anchor in wind and current. I'll use one, but only if I need to reduce the swing for other boats.
