Marking Anchor Rode
89SeaRay220
So with my new windlass, I also got new chain/line, and i'd like to know the best way to mark the line so I know how much scope I let out. I have 10' of G4 chain and 200' of 8-brait line. Thanks!
Dan
We have used electrical ties, either different colors or different numbers. With longer rodes we mark every 50 feet. With a shorter rode you might want to mark at 25 feet intervals. The electrical ties go thru the windlass easily and can be easily be replaced. I have found that the "markers" sold tend to detiorrate. I have sewn them in as well as woven them between strands.
You can't figure out your scope unless you have a depth sounder and know how much line is out.
The Medof Rode Markers are the strongest I've been able to find. Reinforced plastic and a little stiffer than most. Actually, the softer markers will last for years, depending on bottom conditions and your deck hardware. I had my last set 10 years, but I anchor by hand. I've had the Medof Markers a year so far.
If you use 3-stranded anchor line, you just twist open the braid and slip the marker in. Then twist the braid tight again. No sewing needed. I never had one fall out, but I had an old one ripped out by a snag, once. Here are the Medof Rode Markers (about $4):
Yes, the numbers on the markers can mean anything you want them to mean: feet, yards, fathoms, cubits, etc.
I also mark anchor line with ordinary colored electrical shrink wrap. That stuff will stay on three-stranded line almost forever but there are no printed numbers. You have to color code it yourself.
Decide whether to include the chain in setting your markers. If you include the chain, you'll have to re-do the markers if you go to a longer chain at some future time.
if you often control windlass from the helm, make sure you can see the markers... i use paint on my all chain rode... one short mark (about 4") for 25', one long (8") for 100'. ex.. 3 short = 75... 1 long 2 short is 150 etc... i often anchor out at night and with the spotlight aimed at the windlass i can see the markers. they just need to be resprayed every few months, especially the first 3 since they get the most wear.
If you're concerned the windlass will take the twisted labels out of the line, you could do your measuring, mask off a few inches at your intervals, and apply some paint [I'm thinking of the flourescent spray] to say 6" of the line. You'd have to count the dots as the rode paid out. I suppose you could get fancy and do One-Orange, Two-Orange, Three-Orange then One-Green-Two-Green, etc to let you "read" the marks more easily.
I laid out 150' of rode on the dock. then from the anchor hock measured out 20' increments. then I used fluorescent yarn and wove it into the line. a different color for each marker. then I took a scrap of each laid it onto a card and laminated it. now just by color I can tell how much line is out.
including the card it took me about an hour.
Are you talking about heat shrink tubing? If so, how do you shrink the tubing without burning the line? Could common colored electical tape work, or would the salt water make it fall right off?
I was also thinking of buying colored nylon twine, and wrapping the rope with that...any opinions?
Dan
Dan
Yes, I use electrical heat shrink tubing and with an electric heat gun: normal heat setting (not "high") on high quality heat-treated, coated nylon 3-strand anchor line. I use about a 1" band of shrink tubing and heat it while turning the gun around the rope. The shrink tubing will contract quickly and you will hardly be able to feel any remaining heat on the rope. That rope will be barely warm to the touch.
Colored electrical ties at (your call) intervals. If you use 25' for example, the fifth color should be the same as the first. Color 1 when seen the second time would indicate 125 feet. Don't worry about the chain.
yzer,
For 1/2" line, what size tubing should I buy? I don't own a heat gun, I usually just use a small torch to shrink the tubing, that is why i was worried about burning the line. Do you think I could use a hair dryer, would that generate enough heat to shrink the tubing? Do they sell the tubing without an adhesive, or should i use adhesive backed tubing? Sorry about the 20 Questions!
-Dan
I don't have either of my anchor lines marked. What I do is after I have let out about the length that I need based on water depth + distance from pulpit to water is to look at the degree of angle of my rode. If the rode is 180* to the water [straight down], my scope is waaaay to little. I like my rode to be at least 45*, but I just eyeball it til it looks right. If conditions worsen, then I let another 10-20 ft of rode. Works for me and I don't have to do all that work of marking the rode, etc.
Of course I anchor in inland sheltered waters........
yzer,
-Dan
I use 1/2" line too, with 35' of ACCO 5/16" BBB chain. I can't tell you what size the heat shrink tubing is. I don't remember and I'm at home, not at the boat. I do remember: it was Ancor electrical heat shrink tubing (non-adhesive) that was left over after rewiring the boat. I bought some more to finish the job on the anchor rode. The size is the smallest size that will fit over the 1/2" line before heat shrinking.
I use an Ace Hardware heat gun that can be purchased for less than $15. It's a glorified (but much hotter) version of a hair drier. It's an essential tool for boat work: good for everything from stripping paint and varnish to fitting flexible waste hose and for use in marine wiring. I also have a pocket-sized Ancor butane torch, but the pinpoint flame from this is not what you want for this job.
You can see one of the red shrink-tubing markers next to a Medof marker in this picture. I use the heat shrink tubing to mark every 10'. I also use 10-year-old left-over numbered tag markers from my old anchor rode that are marked differently from the Medof markers. You can see one of those yellow markers at the edge of the photo, near the water line. No sense in throwing those away when they are still as good as new!
