Mercruiser Shift Control Identification
Capt Quahog
Does any one know the model of the shift control pictured below? It is mated to a 1993 Mercruiser 5.0LX. I have searched quite a bit and can't seem to find it. I need to replace the trim switch button in mine, but it has no label or model listed on it. I know I can take it all apart and bring it to the Merc dealer, but I would rather just pick up the part and fix it on the boat.
yvt7pt
I have the Merc/Quicksilver Remote Control Service Manual for many of the styles. According to your picture, yours included. My manual was printed in 1989. Most of the info is regarding cable replacement, but I did find instructions for removing the control lever cover and access the internal parts. It also identifies the individual parts and placement.
If you can email me your fax number, I'll fax those pages to you. boaterbetsy at gmaildotcom.
I'll be leaving for the boat in about 2 hrs, so I need the number now or I'll fax them on Sunday when I return.
Thank you very much! I just sent the fax number to you.
Have fun on the boat!
I'm going to fax two different ones. One is older then the other. These pages were back to back, so they will arrive out of order. total 20 pages.
Are you talking about the button below the handle? I've had to fix a couple similar to yours. There could nbe a plastic backing that has the contact in it. It can pop off and not reattach. Stuff something behind it to keep the contact where it's supposed to be. Crazy glue will hold it temporarily 'til you get it put back together.
All fixed, thanks again Liz. I thought it was the trim switch located in the top of the handle. Turned out to be a bad wire connection inside the unit. I replaced all of the connectors and everything works as it should.
Glad things worked out well for you John! Having the breakdown and parts ID is a big help, I know.
