In CA it would not need to be registered 'cause there is no motor attached. Might be the same in TX!
Someone on Bethel Island had a similar idea. All new construction is required to be 20 ft above the ground. So someone put in the required six 20+ ft pilings. Then they brought in a modular home which was able to float and attached it to the pilings similar to a floating dock. But they left the home on the ground. That way they did not have to climb 20 ft of stairs everytime they went into the house.
But the county said it did not meet code and required they abandon the house or lift it up to the 20 ft mark permanently. So now it sits up 20 ft like all the houses around it. Another shot against good old American ingenuity by the bureaucrats!!!!
