Mildew under bimini top
GrecRI
Last year I had a terrible mildew problem that showed up on my sunbrella top - mostly on the under side of the bimini.
Last Spring, I used the bleach treatment suggested by Sunbrella and got most, but not all of it off. I then waterproofed the outside surfaces.
From everything I read, air movement will help to prevent this problem. Unfortunately, I can't leave any of the plastic windows open or off without getting the cockpit wet if it rains. So I hang a stay-dry bag in the cockpit and leave a small fan running when I close up. I also leave the transom door, which faces south, open so it can catch some of the predominently southerly breeze.
Despite all that, I recently noticed mildew starting to return on the underside of the bimini.
When I cleaned the canvas in the Spring, I only water-proofed the outside surfaces. Should I have sprayed the inside of the Sunbrella as well?
If not, any ideas as to why this keeps happening and how to prevent it?
I doubt coating the inside will help. The mildew (fungus) feeds on dirt that gets in the fabric, usually from the outside.
If your top is made with Sunbrella Plus, which has a urethane coating on the inside of the fabric, then dirt, etc that gets into the fabric will get trapped. If it's the coated stuff it will have what looks like a very thin film, usually a bit milky looking, on the underside - not raw fabric weave. My experience is that the Plus tends to mildew much worse due to trapped dirt.
Whether its coated or not, about all you can do is keep it clean and coat it as you have done previously.
Try a larger fan that really gets the air moving. That might help you out, I've seen it done on a few boats.
Jonathan
As long as you have one mildew spore in the fabric, you will get more mildew. It is nearly impossible to get 100% of the mildew out! So each time you see some mildew, even a very small bit, clean it as soon as possible. Keep doing this all the time! That will prevent it from getting worse. During the winter, try to clean it again 2-3 times, otherwise in the spring it will be back again.......just keep after it as frequently as possible!
Or replace the bimini........
We've taken ours off and machine washed them in the HD machines at the laundrymat(sp). That seemed to work and kept the mildew at bay for a couple of years. It came back with a vengence this year (wet spring). We keep the screens open as much as we can which helps. I refuse to leave those 12 volt fans running unattended, almost burnt our boat down last year when we left one running in the cabin.
Boat US makes a mildew cleaner in a green and silver bottle, not sure what the name is, but I use it all the time. You need to hose down the fabric fist then spray on, I use a scrub brush and work it in. Takes all mold out, and lasts about 3 months. BTW, my boat is in Florida where humidity and moisture are a constant problem all year long. I also wash my boat down with water evrytime we go out and wash with oropine with wax every other time we go out, seams to keep everything off of the boat, if you don't do that down here, you will be buffing and waxing alot more than normal, the sun is brutal on gel coats!
I am also experimenting with different type of waxes, bottom half I did with nu-finish, second coat goes on this week, top half will be done with 3-m wax. I will keep you posted as to the outcome!
I'll check it out. I tried a few things last year, none of which worked. It would be great to find something to use besides bleach.
Do you need to re-waterproof after using that product?
I have always just used my small electric pressure washer. Not enough psi to hurt the threads or material and knocks the mildew off.
GrecRI
I usually waterproof once a year. You can spray on yourself, or have your local canvas shop do it for you. If you want, when I get my boat back from being repaired, I can let you know what the stuff is called that I use, it has no bleach in it, and works well.
I water proofed fine this spring after the bleach treatment. I just wonder if it would have made sense to water proof the underside of the canvas as well as the outside.
After thinking about your post related to the stuff in the green/silver bottle, something rang a bell. I checked my shelf for the stuff I had used to try removing the mildew last year. Sure enough, green/silver bottle - 303.
I tried it last year and even added non-chlorine bleach per the instructions. No dice. Hardly touched it..I'll try it again this weekend. Maybe it will work while the mildew problem is mild.
Get the boat back tomorrow! Finally, and I will see what the name is, I never add anything to it. I just did my flybrige bimini a few weeks ago, 1 application, scrubbed with a scrub brush, and hosed off. Once it was dry the next day I could see that all of the mold was gone. I will pick up this thread on Saturday and let you know what its called.
Grec,
I see you are from Warwick R.I.? Years ago, my family used to boat in the Narragansett Bay area, we had a summer home on Prudence Island. Have not been up there since 1995. Beautiful Bay, great scenery.
The Northern end of Prudence Island is still uninhabited, as is all of Patience Island, Hope Island, and Dutch Island. When my brother visits from Florida, he is always amazed at how dark the bay can be at night, with no lights in the middle of the West Passage around the areas of those islands - and how there are no condos, high rises, etc along the shore.
We were clamming (quahogging in RI) between the islands last weekend.
Got mostly hogs, so we made a chowder instead of casinos. I may head to the east side of Prudence this weekend, where a friend of mine got some small ones. Just kind of a bonus to taking a swim.
We've often spoke about how nice it would be to live on Prudence.
