When we test fuel (for commercial facilities), we pull three samples; one from near the top, a second from mid level and the third from near the bottom. Each test will reveal a difference in fuel quality, however since all fuel tanks pull from near the bottom this would indicate that new, fresh gas usually remains near the top being that it is lighter in weight.
In building fuel storage tanks, it was required to provide sample ports that would spiral around the tanks along the stairway. Fuel grade (and quality) is determined by weight and temperature - pilots take on "x" number of pounds of fuel and use "x" number of pounds per hour. Few people are aware that fuel is sold by the pound (from Texas, La & Oklahoma) but marketed by the gallon at the pump.
So would I add 2 gallons to 150 gallons, no. If I noticed performance issues with todays gasoline I would certainly look at the cost factor. Dumping 200 gallons which costed $3 a gallon and replacing with 200 gallon of fuel at $5 is $1600 compared to a fatal engine failure?
