MMSI numbers
Well-known member
I never got around to getting a MMSI number and now i dont hear anything about them any more. Is it worth registering or has the idea died?
MMSI is becoming more and more useful. If you want to take full advantage of USCG Rescue 21 capabilities, AIS, and newest calling/polling functions on latest radios, it's definitely worth your effort. It can save your butt the day you need to get out and swim.
Registering with BoatUS is fine if you only boat in US waters. Register directly with FCC if doing any sort of international boating (other countries don't have access to the BoatUS database, but the FCC database is shared).
"Another advantages is if you know your friends MMSI you can contact him direct."
Unless it has gotten a lot better it ie easier trying to hit your friend in the head with your cell and THEN talk to him then using the direct call function and at the end you are just talking on the same channel as if you had hailed him on 16 andagreed ona working channel.
I got one last and this year I will connect the radio to the gps so our position is available. I don't ever see myself contacting another boat with it. Hopefully it is one of those things that just works when you need it!!
Niles
Some radios have a feature that allows you to plot your buddies on your chartplotter based upon their GPS position report to your radio. Haven't tried it yet, but it sounds cool. May be a limited range, though. Maybe it'd be nice if you're cruising together in reduced visibility or crowded waters.
We have had our for a few years. Hooked up to our Garmin GPS for the positioning feature as well. The numbers are entered into our base unit as well as the Handheld, both are SH.
Can't plot crap if u have a rayjunk product. Apparently raymaine doesnt transmit the " seconds " portion of ur postion... so ur off by MILES... GARMIN transmits the complete location data. The calling another radio feature simply sounds an alarm on the reciepiants radio then once u aknowledge it simply brings u to another channel that can have other chatter. Useful? ... no idea ..
