We owned our 1988 3257 Montego for 9 years. You want to go fast but not go broke, this is a contradiction in terms. If you want speed, you need larger engines. Larger engines translate to more fuel. If you own a boat you go broke. That is a given. Also the beam is 12'4" not close to 13'.
Here are some facts on the boat.
Model Montego
Length LWL 32' 3"
Length w Bow Pulpit 33' 9"
Length w Swim Platform 35' 3"
Length Over All 36' 9"
Beam 12' 4"
Draft 33"
Bridge Clearance 9'
Bridge Clearance w Radar Arch 12' 9"
Deadrise Transom 6 degrees
Displacement Dry 12,145
Cabin Head room 6' 5"
Sleeping Capacity 6
Fuel System 192 gls
Water Capacity 65 gls
Hot Water Heater 11 gls
Waste Water 20 gls
Generator Kohler 7.3
Propeller Shafts 1 1/4"
Rudders Bronze
Struts Bronze
Propellers 18 x 21 4 blade Bronze
Cruise speed with 454 inboards with 1.99 ratio Velvet V-drives:
3250-3270rpm. 27-28mph with a burn rate of 28-29gls per hour.
WOT 4200-4400 34-36mph Burn rate 36-38 gls.
I installed the Navman fuel monitoring system and performed tests on our boat.
I would shy away from the 350's They will burn less, cruise speed will be less, and engines will work harder. Stick with the 454's.
We enjoyed our boat and spent many vacation out to Block Island, Montauk, Conn,and the Jersey Shore.
The largest wave we went through with her were 6ft. You felt it in the aft due to the flat bottom, however in a mild chop she runs nice. Also she is a very dry riding boat with a very large front entry, similar to the front entries on the ocean convertible.
Below is a link of our prior to selling her back in Oct of 2007.
http://www.pbase.com/rbutka
