Mooring ball question
drfeno
I'm new to boating and cruising in general. Still getting used to docking and navigating, but its going well. Since I'm still not very experienced, if I go cruising I'd prefer a mooring to a marina. What is the configuration of a typical mooring ball, and what is the proper way to tie up to one?
I put the mooring bouy beside the swim platform, run 2 large size lines thru the steel ring, walk the lines around, and tie the end of each line to a cleat on either side of the bow. This gives you 2 lines, double the security and stregnth. Most of the sailboaters on lake erie do this also. This also makes it easy to leave, just remove the lines on one side of the boat and pull them thru the loop on the mooring, gone in 60 seconds!!!! Don't tie a line to the mooring, that can be very difficult to remove, especially if the weather turns. I'm sure other will have tips and tricks also
i agree about the line thru the eye if your mooring doesn't have a line already waiting.
it depends on the mooring, some do have a line, others don't. in some case the line will be too dirty to put on the boat so passing your own line thru the eye makes sense.
if you stay on a mooring for more than a couple of days, and if you pass your own line thru a steel eye or thru the eye of the mooring line, then make sure it doens't chafe and get weaken.
if you are alone, and it's windy, it will be easier to pick up the mooring at the stern, off the side, and walk it to the bow with a LONG line. Otherwise byt the time you get to the bow, the boat may have drifted away.
check this out...[http://www.westmarine.com/webapp/wcs/stores/servlet/westadvisor/10001/-1/10001/MooringSystems.htm]
Thanks, any advice is good advice. Do most moorings have their own lines? I do like the Idea of just using my lines through the ring, and releasing them to get underway.
Our steel hulled boat has an opera table claw-eye. Most of the moorings in our area have a 4’ wire rope with a buoy and eye. We made a hookup device out of a 6’ line and a 6’ piece of rebar with an eye bend at one end and a hook bend at the other end. The end of the rebar line is tied off to the boat. All we have to do is bring the bow up to the ball and reach down to the wire rope eye with the hook. Once hooked, simply drop the length of rebar into the water and haul the boat to the ball with the line attached to the rebar. When close enough, slip the wire rope eye into the claw eye at the bow. Stow the rebar/line assembly and you’re done.
I see you're in the North East. I have found that most moorings have a line. A typical set-up is a float with a whip sticking above the water. Grab the whip and pull it aboard. the mooring line will be attached. In some harbors (Block and Edgartown come to mind) there will be a ball and you will have to snag the line with a boat hook. I have the wife go forward and grab the line and put it on my forward cleat. Grabbing from the stern is an option if you are single handed. Just don't back down on the mooring and foul your prop.
To continue the newbie mooring ball questions - what is proper in terms of using a mooring ball - who do you contact to get permission to use it, or are they typically first come, first served??? Do you typically pay someone to use their mooring? If so, how do you know who to contact to make all the arrangements? I'm specifically wondering about Block Island, the Vineyard, Nantucket and Newport.
TIA,
Thanks everyone,
I also have all the same questions as Sandy K, I just figured I learn how to tie up to one before I asked The procedural questions.
All moorings belong to someone. It is not good etiquette to jump a mooring if you don't know who it belongs to. There's nothing worse than getting kicked off by the owner who returns from a day of boating.
Having said that, many harbors, such as the ones mentioned above have moorings available to the public rented out by either the town (harbormaster) or some private organization/marina. The best bet is to consult cruising guides or the harbormaster for information on mooring availablity.
Specifically, Block has town moorings available thru the harbormaster on a first come first serve basis. You pick up a green or orange mooring and they will come over to you a some point for the fee $35 or $40/night. Newport, contact Old Port Marine and use same drill. Edgartown, contact harbormaster, they have reservation moorings and first come/fs. Natucket, contact Nantucket Moorings. Vineyard Haven, contact harbormaster. Cuttyhunk, first come/fs, just pick up what's available. All town moorings in inner harbor are marked as such. If not marked, they are private. Frog Pond marina has moorings for rent outside the pond which are green. The rates these places are all in the 30-40/night range. Some include launch service and other facilities like showers.
With first come/fs serve, usually you can pick up the mooring without hailing anyone. If you have a reservation, you can hail the appropriate party and they will often lead you to the right spot.
Being on a mooring is great fun. It's a lot like being in a camp ground. Although I also enjoy slips, you can't beat moorings on price. Hope that helps.....
Thanks Prospective, that definitely helps. I'm also interested in checking out Sag Harbor and Greenport. I figure the same drill applies, contact the harbormaster for information. I would definitely be interested in something I could reserve, at least at first. It would really put my mind at ease going into a harbor I've never been to to know I had a place to tie up.
Just need to say that all moorings are NOT the same. They are set up specifically for whose boat will be on it. If you were to hook up a 30 foot boat to a mooring with only a 100 lb anchor and small chain that would hold only a 15 ft boat, you could be in real trouble. You could also break it to a point where you would have to replace it. Every mooring belongs to someone and they are not cheap to buy and/or maintain. I know. I am on a mooring. My 28 ft calls for a 250-300 lb mushroom anchor. I have a 350 lb for extra safety.
Be careful about simply running a line through the mooring eye and back to the boat. I had a similar line chafe through about one in the morning in Man-O-War Cay harbor. Winds were blowing about 20 knots and the braided 3/4 inch line parted suddenly.
Chaos resulted and fortunately I was able to get up, start the engines and move the boat before I drifted back into the other boats. Luckily I had also dropped my anchor and it caught me just short of the next boat in the mooring field.
After that episode I now use a very large shackle through the mooring eye to which is also attached two lines that have metal loops on the end. The lines then run back to the cleats. No problems.
Have your lines ready, pull up the mooring ball and attach the shackle (with lines) to it.
