motor size
dcs
i have purchased a 11 ft zodiac to use for coastal fishing/ sight seeing etc when we are camping at the north end of vancouver island. we would have to launch from shore and pack our motor to the boat. i need help decideing on what motor to buy. i,m thinking of the yamaha 8 hp 2 stroke becausr of weight for packing but not sure if it has enough power. any help would be appreciated as i am atotal newbie. thanx craig
What's the max HP rating for that boat?
8 HP will move you along nicely. Will it mostly be just you or will you have a passenger along?
I have a 7.5 on a 8ft Avon and it moves, a little to fast. I might get a smaller one because of weight for carrying. I use a new 6 on a 18 ft duck boat up north and that thing gets up and goes just fine with two people, With three and decoys (Plus Robo Duck) it is a trawler.
there will be two people plus fishing equipment and occaissionly our 25 # dog.
Yikes! Two people+fishing equipment+dog in an 11' boat. You are going to run out of room in a hurry.
To answer your question though, 8HP should be fine.
Craig i had a 9.9 2 stroke on a 10 foot Zodiac lots of get up and go. 8 hp should be fine You may regret the 2 stroke if you travel far distances. Better gas economy with a 4 stroke. I now run a yamaha 15 on that same Zodiac 310 s i think is model. I bought that to pull kids on ski tube.
Fuel consumption is not going to be that different on the small motors. And the 2-strokes are lighter, far easier to store (you can lay them down just about any way you want), provide a lot more grunt at low revs and are just overall a superior type of power. The manatee huggers will scream, but that's the facts. And the 8 should give you all you need on that little boat.
Yah what good is a small outboard if there is not a rainbow trailing behind it....HA HA!!
my 11' rigid bottom dingy planes well with 15Hp with 2 people. I dont know if it would plane with an 8.
You may want to consider some type of dolly or other beach tire wheeled transport of both the engine and inflatable (an 11 foot Zodiac is going to be in the way of 75 lbs min, up to 170 lbs, plus gas, gear etc). The engine is going to start in the 75 lb to 120 lb range. First what size engine is the Zodiac rated for? Probably 15 hp. If you want to go any distance, I would opt for a 15 hp. But 8 would be a minimum for that size boat.
You can also buy "Beach wheels" for the inflatable. We have them on a boat that size and have used them on larger boats. They can either detatch or fold up--the balloon tires are necessary--and you can even tow the inflatable behind a car very slowly in the camp ground. This way, you can inflate the boat, with a 12 volt inflator, have the engine and fuel loaded and then wheel the boat to the water's edge. Also remember the exteme tides in this area. Beach wheels for inflatables are popular with west coast cruising boats.
