Mounting a flag
  • Thread starter Thread starter blouderback
  • Start date Start date
Bob,
If you mount the flag in the center of the stern there is a good chance it will "pop" less when you are running.
Bob,
Soldering is not advised. It causes the copper wire strands to become brittle and they will eventually break due to the usual boating vibrations/banging. Crimp and cover with heatshrink as already advised. BTW, we can do this in your driveway as long as you keep the coffee hot and the beer cold. ;) (We aren't selling the Chalfont house until the Admiral retires in a couple of years).
OK, Mike, good to hear (about Chalfont), and thanks for the offer! Thanks for the tips on making electrical connections. I hadn't thought of solder becoming brittle and cracking.
Crimp and shrink tube it. Should have a mechanical connection - I'd est, properly crimped (Amphenol crimpers make a nasty little crimp that will NOT slip, but are prone to damaging the insulation on the connector), protected from the environment by means of shrink tube, preferably the kind with the shmoo lining the inside, and the wires properly routed. That is to say, either in conduit or supported every 12 to 18 inches and not in direct contact with any structure. If you're running near speaker wires or anything magnetically sensitive, you need to consider that.
The nylon coated butt connectors do not crack or smash open like the plastic ones do. They are a little more expensive, but worth it.
indeed, no soldering. crimp it either with butt connectors which already have the shrink tube, or use regular butt connectors plus shrink tubes. I also always put some dielectic grease on the wire before putting them in the connector.
and obviously, use marine tinned wire, not plain copper or, worst, solid home wires.
Wiring in two seperate mountings for the light staff is fine. However, among some of the other issues/advise mentioned above, you will need to be concerned about the mount itself. When you have the light staff installed in one of the mounts and energized, the unused mount will also be energized. It's only 12volts, so there really isn't much of a safety hazard, but if kids are onboard, they may stick their fingers in the 'empty' mount and get a little shock. The mounts may have a small drain hole in the base, but they are prone to clogging. Spray could then get into the empty side and short the + to the -. At the very least, you will want to have a secure, water tight cap for both mounts (should come with the new mount) or better yet, wire in an 'a/b' switch so that only one side is energized at the time.
I installed a staff support on the transom of my boat. I noticed that the pretty wooden staff did not fit snugly into the holder, so I made a lanyard to secure the staff to the boat. More then one time after running through chop or wakes, the staff has bounced out of the holder, but I've never lost my flag!
Post some pictures when you have it all installed!
OK, will do. I think I'm going to install it in the center of the transom, and not wire it up.
