I want to replace my old CRT TV with LCD.
Current TV is mounted in a floor level cabinet in the salon. Above the cabinet is window.
Does anyone have expereince with a lift type mount? I was thinking I could install Lift mount and LCD in cabinet, cut hole in top of cabinet and be able to lift LCD through the top for viewing. I don't need a powered lift. The cabinet will fit a 26" wide LCD (actual width not diagonal screen size).
Trying to avoid viewing at a down angle as is current set-up, but if no easy lift mount available, I guess can use mount within cabinet that swivels slightly upwards.
Sorry, no pics of current setup right now.
