MST Guardian
cdlomb86
Looking for info on MST guardian anyone install one or have info good and bad. thanks in advance.
We are talking to them about adding the product line. There were some patent issues involved so we need to make sure those are resolved before we can move forward.
Ken, my units flushed in through two ports on the block and circulated throughout. I could feel the temperature of the termostat housing drop when I ran the system. It also pulsed, helping clean the block. I never had any overheating problems, even after five years with the same risers and manifolds.
Ken, flushing takes place upon return to the dock - the engine is still warm and the thermostat still open. I liked my system because of the simplicity. I had a quick connect fitting on the hose and on the system. I just simply snapped the hose into place, turned on the hose and let it run for a few minutes. I'm sure you could jury rig some alternate but the systems are not expensive. Plus you'd lose the pressure regulating feature that prevents blowing out gaskets.
CaptKen... what do you recommend instead of the MST/SuperFlush system?
Esteban
