muskrats
fannese
I have a 4.3 mercruiser with an alpha drive. Is there a way to temporarily fix the shift cable boot from leaking-it has a two inch small hole, appears to be from muskrats? Quick fix? Thanks
Your heading isn't attracting mechanics who can help you. Why not change it?
Hey Fannese,
As Flutterby said," Your heading isn't attracting mechanics who can help you", but I came prepared to assist with your muskrat issue.
However seeing that your real issue is a dried out decayed rubber hose that have a history of sinking many a boats while the owner is away I would recommend either to replace the 'boot' or get rid of the boat.
Fair Well,
El Sea
Get the shift cable bellow replaced as soon as possible. The only quick fix is replacement. You don't state the age of your dirve, but if it's more than 5 years old, you may want to consider having the drive shaft bellows replaced at the same time.
Thanks for your reply. Boat is a 99 REgal LSR 21. The bellows have all been replaced recently. The shift bellows is still soft and has more of a tear than a hole. I put small plastic (4) along the length to hold it to the cable jacket and added silicone so my children could use it this weekend. Three drips every minute go to the bildge area. I was just hoping there may have been a quick fix to get through the weekend. I do have a float switch also. I made the cardinel mistake of leaving in the water at the dock with our drive turned to the right which exposed the bellows for the muskrat to feast on. only Mercruiser do you have to remove entire outdrive to replace cable. Thanks for your answer.
You might set out some traps. If you get a couple hundred of those Muskrats you can make a pretty nice Fur coat.
Then sell the coat for enough to replace all that rubber stuff.
