My Light Requirements?
fountain27
Boat length 33'.
I have a 1 white light facing forward at the windshield and 1 at the stern. In addition I have 1 white mounted on top of radar arch.
Here is my question, my new radar partially blocks the white light on the radar arch; is this a violation?
It appears from this (http://www.boatingbasicsonline.com/course/boating/4_2_b.php) I am only required to display 2 white lights.
underway you must show the forward white light and the stern light.
anchored you must show the 360deg all around, it shoudlnt' be blocked by radar. you need to extend the tube on which the light is mounted to be higher than the radar.
note that under 12m, you can combine the forward and stern light and only show the all around white.
"note that under 12m, you can combine the forward and stern light and only show the all around white."
I've been waiting for just such a Posting cause I'm dumb and don't know the conversion for 12m. But then again....if you can display the all-around white under 12m......then does that mean that you can't if you're OVER 12m.......???....My Boat is either 27-----------28---------or 32ft. depending on where a person wants to measure it.......So can I display an all-around white light?
12 meters = 39.36 feet (1 meter = 3.28 feet). So, you are either 8.23 ------- 8.50 ----- or 9.75 meters long.
So the answer is Yes, according to my math.
An excerpt form the NavRules ( available on this forum... )
Rule 21
(e) “All-round light” means a light showing an unbroken light over
an arc of the horizon of 360 degrees.
Rule 23
Power-driven Vessels Underway
(a) A power-driven vessel underway shall exhibit:
(i) a masthead light forward;
(ii) a second masthead light abaft of and higher than the forward
one; except that a vessel of less than 50 meters in length shall
not be obliged to exhibit such light but may do so;
(iii) sidelights; and
(iv) a sternlight.
<snip>
(c) (i) A power-driven vessel of less than 12 meters in length may
in lieu of the lights prescribed in paragraph (a) of this Rule
exhibit an all-round white light and sidelights;
I hope that covers it.
How To Measure Length
A motor boat is measured along its centerline from the outside of the hull aft to the outside of the hull forward. This measurement does not include any attachments such as swim platforms, outboard motors, bow sprits, etc. This measurement is called the length overall (LOA).
http://www.boatingbasicsonline.com/course/boating/3_3.php
PLEASE take a boaters safety class.
This online one is free
it's not up to you to measure your boat, or the marina to charge you a couple of feet. the official LOA will be on your registration or documentation based on what the builder stated in the Certificate of Origin. This is is the only thing that will be valid if the USCG or state officials challenge your lights...
pretty clear looking at the nav rules that you can show an all around in place of the masthead and stern lights if you're over 12m
if i'm not mistaken, the USCG navrules booklet include relevant metric to feet conversions.
