TIC,
The running lights signal to other boaters that you are under command, and if your masthead light is lit, under power. If another boat is approaching you from your starboard side (seeing you green running light) they will assume that you are the burdened vessel and will adjust your course/speed to avoid them. When your running lights are on at anchor, you are relying on the other boat, at night, to figure out that you are not under power and to take evasive action to avoid you. That is why it is dangerous.
