Need a replacement cabin key
PatSea
I need a replacement key for the sliding cabin door. It works by placing the key in the lock, turning it about 45 degrees and pulling it out. This leaves a small (1" long) piece in the lock which provides the locking function. I visited the Wellcraft dealer (It's an '87 Wellcraft St Tropez) and he said the key was no longer available from Wellcraft, and I would need to buy an aftermarket lockset with key. Does this sound right? Where can I buy such a lockset?
If you have a key, a locksmith can probably make a duplicate ... if you have lost the key a locksmith may still be able to help. I needed a duplicate key for my boat and even though the locksmith did not have the corect blank he was able to use one that was "close" and make a key that works.
I had the same deal several years back. Most of the cabin locks are Attwood or Perko. Mine was a Perko, so I emailed them, and they responded by saying that if I sent them a copy of the title and wrote the number off the lockset, that they would send me a set of keys, which they did for no charge.
